904 Rear servo spring.
#2579436
11/17/18 03:20 AM
11/17/18 03:20 AM
Posts: 117 Aus
hysteric
Aus
I went with the the fairbanks shift kit and the spring they provide for the reverse low servo is too big to fit the billet A&A servo. The strange thing about it is the the 3 coil spring does feels stiffer than the 6 coil spring provided in the fairbanks kit.
Is stiffer better? I'm going for the full manual set up.
Or should i find a replacement spring?
Re: 904 Rear servo spring.
[Re: hysteric]
#2579649
11/17/18 08:10 PM
11/17/18 08:10 PM
Posts: 25,729 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Stiffer spring makes the rear band release quicker on the 1-2 upshift if you have LBA.
[Re: humpty]
#2580350
11/19/18 09:51 PM
11/19/18 09:51 PM
John_Kunkel
Rio Linda, CA
I use the stock spring and servo and have no issues with the 1-2 shift. You do, you just don't notice it.
[Re: hysteric]
#2580507
11/20/18 04:19 AM
11/20/18 04:19 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
We put an A & A reverse manual valve body in my sons Dart and used the A & A rear servo piston and spring. He recommended we use it as its a low band apply valve body we put in my boys Dart. We cant notice any different in the 1-2 shift and the car did not slow down any. And the old valve body was a no low band apply. Ron
