TTI 2-1/8th Step Headers Fitment #2575990
11/08/18 06:31 PM
11/08/18 06:31 PM
N.E. Ohio
6bblFLASH Offline OP
N.E. Ohio
Looking at getting some TTI 2-1/8th step headers for my street car.
Automatic column shift.
Steering is a power rack-front steer ,so really the only concerns are torsion bars and shifter. I can fab anything required for the shifter .So that is a minor issue.
Has Stage 6 heads ,straight plugs.
Looked on their webpage and lists the shifter issues and sparkplug clearance mods.
Would like to hear about actual users opinions...........
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: TTI 2-1/8th Step Headers Fitment [Re: 6bblFLASH] #2576042
11/08/18 08:19 PM
11/08/18 08:19 PM
AndyF Offline
AndyF  Offline
What car and which engine? I have the 2 1/8 low deck headers on a 470 with Trick Flow heads and I've come to conclusion that I should sell these headers before I use them and put something smaller on the car. The headers fit very nicely but they use up all of the space so it is difficult to access anything once they are installed.
Re: TTI 2-1/8th Step Headers Fitment [Re: AndyF] #2576051
11/08/18 08:52 PM
11/08/18 08:52 PM
N.E. Ohio
N.E. Ohio
Oh crap. My mistake
68 B body 440 RB
Re: TTI 2-1/8th Step Headers Fitment [Re: 6bblFLASH] #2576136
11/09/18 12:33 AM
11/09/18 12:33 AM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Dennis I have those on my wagon(67 b body). They fit very well except the starter. They are really close. I used lava shield mat to protect the starter. Not sure about the column shifter. Whish I could help more.
Ok
Re: TTI 2-1/8th Step Headers Fitment [Re: 6bblFLASH] #2576213
11/09/18 03:17 AM
11/09/18 03:17 AM
Dearborn Hts, MI
Sledge_57 Offline
Sledge_57  Offline
Dearborn Hts, MI
Straight plugs are not going to work unless you beat the crap out of every tube. I have them on mine with angled plugs and they fit good except #5 which isn't possible to even get a socket on the plug without removing the header. So come spring off the drivers side comes to ding that tube.
Not happy....
On the plus side I do have way more clearance around my shifter (B&M Floor Shifter) cable than the 1 7/8 headers did.
EDIT Oh yea Spark plug boot is pressed hard into the tube, didn't live long....
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
Re: TTI 2-1/8th Step Headers Fitment [Re: Sledge_57] #2576319
11/09/18 01:32 PM
11/09/18 01:32 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
I have these headers on my 63 B body with the -1 heads. The plugs are angled and I can get to them but I could not see using a straight plug head with these headers.
Re: TTI 2-1/8th Step Headers Fitment [Re: max_maniac] #2576365
11/09/18 02:47 PM
11/09/18 02:47 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I put step TTI headers on the 67 this time around, they are nice quality ..
the only thing I ran into was, starter fitment .. crazy tight, tried 3 different ones
all recommended by TTI .. used the clockable one , it helped a bit
still had to make a small clearance spot in one tube 1/2" round, 1/2" deep or so ..
If I would of had T-bars the struggle would of lasted much longer
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: TTI 2-1/8th Step Headers Fitment [Re: 6bblFLASH] #2576481
11/09/18 06:22 PM
11/09/18 06:22 PM
N.E. Ohio
N.E. Ohio
Hmmm
So straight plugs are a tough go.
Not crazy about the starter being tight either.
The engine is lowered 3/4" ,I modified the mounts for the Patriot Headers I have on it now.
They fit Ok on the 383,but not the 440. They weren't listed as B or RB specific.
So my choices are ??
Re: TTI 2-1/8th Step Headers Fitment [Re: cudatom] #2576485
11/09/18 06:25 PM
11/09/18 06:25 PM
N.E. Ohio
N.E. Ohio
Tom,what heads are you using?
Re: TTI 2-1/8th Step Headers Fitment [Re: 6bblFLASH] #2577018
11/11/18 03:51 AM
11/11/18 03:51 AM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Dennis I have edelbrock performers, angle plug. I run straight spark plug boots. I do use the heat socks on themand never had an issue. Also very easy to change plugs and no issue getting a socket on.
Ok
Re: TTI 2-1/8th Step Headers Fitment [Re: cudatom] #2577054
11/11/18 11:22 AM
11/11/18 11:22 AM
N.E. Ohio
N.E. Ohio
OK,thanks.
As stated by others straight plugs are a Bi-ch. catfight
I have another set of Hooker 5209`s. I may try those. Not ideal for what I`m trying do. But known to work.
Thank you to all those that replied with experiences bow
Re: TTI 2-1/8th Step Headers Fitment [Re: 6bblFLASH] #2577119
11/11/18 02:44 PM
11/11/18 02:44 PM
moparx Offline
moparx  Offline
i have a set of 2"-2 1/8" step TTI's i got at carlisle this year for only $175, but the bozo that "clearanced" these had NO CLUE how to use a torch and hammer ! eek spank
good deal for me, but i will replace the bashed sections of tubes with a little more "refined" clearance. biggrin
just the machinist skills showing in me.
beer
Re: TTI 2-1/8th Step Headers Fitment [Re: 6bblFLASH] #2577199
11/11/18 06:53 PM
11/11/18 06:53 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Originally Posted By 6bblFLASH
Oh crap. My mistake
68 B body 440 RB
+ Stage VI heads...
Are you planning to purchase them new? If so, my suggestion is to consider the standard 2" TTI headers, instead. I can go into more details why, if you want. Long story short: fewer fitment issues, from my experience using them in my Challenger with Stage VI heads and a RB block.
