Got a Transmission dyno for the shop
#2576201
11/09/18 02:56 AM
11/09/18 02:56 AM
Posts: 2,771 Cedar Lake IN
CRT
Cedar Lake IN
Re: Got a Transmission dyno for the shop
[Re: CRT]
#2576214
11/09/18 03:21 AM
11/09/18 03:21 AM
Posts: 4,254 Canada
WO23Coronet
Canada
Pretty neat. Will you be able to tell how much hp a transmission uses or how efficient it is? I’m curious how much hp a 46 RH/RE uses compared to a regular 727 or comparable autos
[Re: racerx]
#2576266
11/09/18 11:44 AM
11/09/18 11:44 AM
Posts: 3,069 Michigan
A727Tflite
H Pretty neat. Will you be able to tell how much hp a transmission uses or how efficient it is? I’m curious how much hp a 46 RH/RE uses compared to a regular 727 or comparable autos x2 ….it say dyno I know what it said - looks like just a test stand/run-in stand - the same ones we use in the Reman trans programs.
[Re: CRT]
#2576278
11/09/18 12:20 PM
11/09/18 12:20 PM
Posts: 1,890 Spahn Ranch
RMCHRGR
Spahn Ranch
Would the unit shift on its own if it was attached to the load device?
'71 Duster '17 Ram 1500
[Re: A727Tflite]
#2576283
11/09/18 12:36 PM
11/09/18 12:36 PM
CRT
Cedar Lake IN
Test stand / dyno. Call it what u want.
[Re: CRT]
#2576287
11/09/18 12:40 PM
11/09/18 12:40 PM
CRT
Cedar Lake IN
In the industry it's not called a test stand. But that's what it does. Tests the transmission operation. Its known as a trans dyno. https://www.superflow.com
call it a trans dyno. My car says Dodge but I call it a Mopar.
[Re: CRT]
#2576290
11/09/18 12:45 PM
11/09/18 12:45 PM
A727Tflite
In the industry it's not called a test stand. But that's what it does. Tests the transmission operation. Its known as a trans dyno. https://www.superflow.com 👍
[Re: CRT]
#2576291
11/09/18 12:45 PM
11/09/18 12:45 PM
Posts: 7,479 Minnesota
Hemi_Joel
Minnesota
Good for you, it always feels good to add some useful equipment!
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: CRT]
#2576431
11/09/18 04:36 PM
11/09/18 04:36 PM
Posts: 11,531 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Buddy of mine who builds transmissions built one some years ago using a BB Cheby and a brake affair on the output to load it. Said it's turned out to be invaluable for any number of reasons. I'm sure you'll come to the same conclusion.
[Re: CRT]
#2576438
11/09/18 04:52 PM
11/09/18 04:52 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Very cool, John. I'm sure many customers will appreciate having their transmissions tested before receiving ,especially those not local to you. Will that be a standard service or an option?
2 kids and a dog
[Re: A727Tflite]
#2576443
11/09/18 05:04 PM
11/09/18 05:04 PM
CRT
Cedar Lake IN
From the Axiline Website link you provided :
SuperFlow's Axiline and Hicklin transmission test stands cover the complete range of light-duty, medium-duty, heavy-duty and cross drive transmissions on the market today. With solutions for everything from passenger cars to the M1 tank and features like mechatronic shift controls, no-hassle precision aligment tooling and the available WinDyn Data Acquisition and Control system for fully automated tests and reports, SuperFlow transmission dynos are the only choice of the top transmission remanufacturers world wide. Check out or custom testing solutions page for examples of custom transmission test stands we've built for heavy duty cross drive dynos and full AC regenrative test stands.
All 5 reman transmission remanufacturers i have dealt with over the last 25 years call them either test stands, or for the newer units with electric motors running the input an ETM's - Electric Test Machine.
FINE its a test stand
