69 Charger factory primer color #2574816
11/06/18 01:15 PM
11/06/18 01:15 PM
Wausau,Wisconsin
Kilrbee Offline OP
Kilrbee  Offline OP
Wausau,Wisconsin
I have a 1969 Charger and am wondering what colors of primer did the Hamtramck plant use? I want to do the bottom of my car in the primer color and over spray the body color... any help would be appreciated
Re: 69 Charger factory primer color [Re: Kilrbee] #2574951
11/06/18 05:49 PM
11/06/18 05:49 PM
Greenwood Lake, NY
fuelishnsilly Offline
Greenwood Lake, NY
should have been the dark gray dip tank primer I think.
inherited a 69 roadrunner from my grand pop.
Re: 69 Charger factory primer color [Re: Kilrbee] #2574973
11/06/18 06:30 PM
11/06/18 06:30 PM
Az
69hemibeep Offline
69hemibeep  Offline
Az
What ever shade of gray showed up and poured into the tank
1969 Hemi Roadrunner 2nd owner
Re: 69 Charger factory primer color [Re: 69hemibeep] #2574987
11/06/18 06:48 PM
11/06/18 06:48 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
iagree it varied based on what was in the vat when your car was actually "dipped", your car has the best evidence for what color was on your car - check firewall, floors & inside doors - some unmolested/uncovered areas should still remain scope
Re: 69 Charger factory primer color [Re: Kilrbee] #2575007
11/06/18 07:47 PM
11/06/18 07:47 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The more cars dipped before the vat was topped up, the more debris in the tank also.
Actual shades vary widely due to circumstance.
Re: 69 Charger factory primer color [Re: Alaskan_TA] #2575111
11/06/18 11:35 PM
11/06/18 11:35 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
The color you need can be found on the inner part of the doors behind the door panels, halfway up the firewall behind the heater box, etc.
Re: 69 Charger factory primer color [Re: Kilrbee] #2575221
11/07/18 10:43 AM
11/07/18 10:43 AM
Wausau,Wisconsin
Kilrbee Offline OP
Kilrbee  Offline OP
Wausau,Wisconsin
Thanks everyone for the input, unfortunately this car has been an ongoing restoration since 1992! any trace of original anything is long gone! I was just wanting to know what the original exposed primer color was for the Hamtramck plant cause its about to be painted and I want to do it correctly as the factory would have.
Re: 69 Charger factory primer color [Re: Kilrbee] #2575225
11/07/18 10:58 AM
11/07/18 10:58 AM
MA
steve70 Offline
steve70  Offline
MA
Here are a couple pictures of a Hamtramck built 70 Challenger
1970 Challenger T/A 4 speed
Re: 69 Charger factory primer color [Re: Kilrbee] #2575228
11/07/18 11:02 AM
11/07/18 11:02 AM
cbusters Offline
cbusters  Offline
I had paint matched to the primer color and sprayed with flattener to be more durable.
Re: 69 Charger factory primer color [Re: cbusters] #2575248
11/07/18 11:56 AM
11/07/18 11:56 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I believe Resto Rick also sells a paint formulated this way.
Re: 69 Charger factory primer color [Re: Kilrbee] #2575772
11/08/18 10:50 AM
11/08/18 10:50 AM
Wausau,Wisconsin
Kilrbee Offline OP
Kilrbee  Offline OP
Wausau,Wisconsin
Thanks for the pics, I will do some checking for some correct color paint to use. beer
