Page 3 of 6 1 2 3 4 5 6
Re: Dana 60 [Re: cdwmotorsports] #2574430
11/05/18 03:16 PM
11/05/18 03:16 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Wow!!!! Somebody needs a Snickers Bar. 😂
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Dana 60 [Re: cdwmotorsports] #2574433
11/05/18 03:19 PM
11/05/18 03:19 PM
dogdays Offline
dogdays  Offline
My favorite place to look is '70s F250s. They are everywhere, and they all had a Dana 60.
Be careful when you buy because the Dana 61 is out there in quantity and some of them look pretty good with semi floating hubs (car style). Mostly they come under vans, but they are built for low numerical gears and more of a hassle to regear. The Dana 60 HD has extra beef in the case and is too heavy for a street car, IMHO.
R.
Re: Dana 60 [Re: cdwmotorsports] #2574436
11/05/18 03:24 PM
11/05/18 03:24 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Originally Posted By cdwmotorsports
Also unless you're going to fund my build I don't care that you would use a 9" Ford over a Dana, or a Glide over a 727. Have a great day.
Good answer.
How about an 8-3/4"? stirthepot
Re: Dana 60 [Re: DrCharles] #2574449
11/05/18 03:44 PM
11/05/18 03:44 PM
PA.
"Little"John
"Little"John
PA.
Good answer.
I hear the 7 1/4 rearends are lighter and cheaper
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Dana 60 [Re: cdwmotorsports] #2574469
11/05/18 04:17 PM
11/05/18 04:17 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
haha
I had a 7-1/4 under my first 383 4-speed Valiant for a few weeks. But I also left the stock skinny tires on. Lots of "sound and fury, signifying nothing". 2.76 gears were fun though, I could run 1st up to 65 mph laugh
Would have been interesting to see how long it lasted work Anyway I soon got a good 8-3/4 sure-grip and a pair of Centerlines with 235/60 tires. Still hard to hook up even with 3.23 gears, so it never broke.
Re: Dana 60 [Re: cdwmotorsports] #2574475
11/05/18 04:32 PM
11/05/18 04:32 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
a stock 8.75 is stronger than a stock 9 inch-------and a venerable dana 44 is stronger than a 9 inch-------that said if you go the dana 44 route there is much aftermarket support for it as a 9 inch---and if you are looking at a narrow axle for a back halfed car you can find an easy axle under a 68? jeep wagoneer---the center section is offset so you have a short axle side and a long side you can cut down to size........
Re: Dana 60 [Re: an8sec70cuda] #2574494
11/05/18 05:30 PM
11/05/18 05:30 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Originally Posted By an8sec70cuda
They will most likely come w/ either 4.10 or 3.54 gears and hopefully you'll get the good powerlock diff.
What years/applications used the powerlock? I haven't been able to figure that one out
Re: Dana 60 [Re: cdwmotorsports] #2574496
11/05/18 05:34 PM
11/05/18 05:34 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
i would say the 60,s and early 70,s trucks had the power lock dana 60's----a friend of mine had a 68? date code 8.75 powerlock for sale a while back---couldnt get any takers----might still be laying around....
Re: Dana 60 [Re: DrCharles] #2574581
11/05/18 08:58 PM
11/05/18 08:58 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Good answer.
X2 iagree minus the 8-3/4 part
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Dana 60 [Re: GY3] #2575409
11/07/18 04:21 PM
11/07/18 04:21 PM
an8sec70cuda Offline
Originally Posted By GY3
Yes, the smaller axle tubes will make it easier to use the 8 3/4 shock plates and u-bolts. Mine had the 3.25" tubes and took some convincing to get the u-bolts on.
NAPA has U bolts for the 3.25" axle tubes and they fit right through a factory Mopar shock plate w/ no grinding.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Dana 60 [Re: cdwmotorsports] #2575575
11/07/18 11:05 PM
11/07/18 11:05 PM
aZLiViN
J_BODY Online rolleyes
J_BODY  Online Rolleyes
aZLiViN
I prefer the side adjusters on the S60 over the shims of a D60.... and the 8.75+.25 is a great direction to go.
Re: Dana 60 [Re: J_BODY] #2575614
11/07/18 11:44 PM
11/07/18 11:44 PM
PA.
"Little"John
"Little"John
PA.
Shhhhhh unless you are going to buy it for him he wants to do it his way. With a non Mopar Dana Corporation rearend.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Dana 60 [Re: pittsburghracer] #2575706
11/08/18 02:59 AM
11/08/18 02:59 AM
pacific northwest
Stroker Scamp Online content
Stroker Scamp  Online Content
pacific northwest
Make sure not to pick up one that is the heavy duty like I did,
It has two ribs by the cover. Way too heavy
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Dana 60 [Re: cdwmotorsports] #2575785
11/08/18 11:29 AM
11/08/18 11:29 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Is there any reason why I couldn't cut down a Dana 60 from a Dodge truck to replace my 8.75. I am wanting to us that 8.75 in another A-body and figure if I can get a housing bought cheap I might just start there. What year truck should I look to get one from? What's a good price on a housing?
If you want cheap look at the 9 1/4 rears.
Don't know what you plan on using it for but around here they are dirt cheap.
Don't know why they haven't taken off in the aftermarket?
As for the Dana 9 inch debate it's been done to death.
Re: Dana 60 [Re: MattW] #2575910
11/08/18 03:17 PM
11/08/18 03:17 PM
I think the crush sleeve and taper axle housing and gear selection has made them not popular shruggy
Re: Dana 60 [Re: cdwmotorsports] #2576181
11/09/18 02:19 AM
11/09/18 02:19 AM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Srt-10 Ram came with Dana 60, with lsd and discs. The other rear end that might be useful, is the dana 44 from the back of wk1 jeep.
Re: Dana 60 [Re: cdwmotorsports] #2576234
11/09/18 08:14 AM
11/09/18 08:14 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
No way I'd use a Dana 44. 8.5" ring gear.
Doug
Re: Dana 60 [Re: dvw] #2576242
11/09/18 09:06 AM
11/09/18 09:06 AM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Doug
The Jeep dana 44 hd has an 8.9" ring gear, and the pinion shaft is same size as Dana 60.
Re: Dana 60 [Re: cdwmotorsports] #2576444
11/09/18 05:06 PM
11/09/18 05:06 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Dana 44? Some of you really like beating your heads against the wall.
Re: Dana 60 [Re: cdwmotorsports] #2576629
11/10/18 01:37 AM
11/10/18 01:37 AM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
When I big blocked my w-150, I never once broke the 44 in 4wd, but busted the 9.25" more times than I can remember.
