92 Dakota died #2559207
10/05/18 01:43 AM
10/05/18 01:43 AM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
my trusty 92 died on me 3 times today,first 2 it restarted right up,third time it had to set a minute,,over the years ive replaced the crank sensor a couple times,any bets on that being the problem again?,ive always used genuine mopar parts on it
comments please!!
thanks in advance
Butch
my ladder of success is missing some rungs
Re: 92 Dakota died [Re: rhad] #2559311
10/05/18 10:53 AM
10/05/18 10:53 AM
Guitar Jones Offline
Did it run fine after it restarted? How did it die, like turning the ignition off or did it sputter and die?
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 92 Dakota died [Re: rhad] #2559331
10/05/18 11:44 AM
10/05/18 11:44 AM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Shot in the dark here, but I had the same thing happen with my 5.2 dakota.
It was the fuel pump going bad. If you have to replace one, take the bed loose and get a couple buddies to help you move it. Fuel pump ring is right on top of the tank. You will need a strap wrench or BIG channel locks to remove the threaded ring.
Re: 92 Dakota died [Re: rhad] #2559346
10/05/18 12:13 PM
10/05/18 12:13 PM
Cleveland Ohio
sportfury70 Offline
sportfury70  Offline
Cleveland Ohio
Corroded wire under hood on left front fender. Don't recall which one but very common issue with the generation of Dakota
Re: 92 Dakota died [Re: sportfury70] #2559677
10/05/18 10:40 PM
10/05/18 10:40 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
That would be the junction where 5 wires that are ignition power are factory spliced together (mine were pink with a blue tracer) between the master cylinder and the under hood fuse box on the newer ones, and between the master cylinder and the battery on the older ones.
My 93 would loose the power to the fuel pump relay in the under hood fuse box, but I've seen them loose power to the cam sensor and the crank sensor also. If you have something in the ignition circuit that doesn't have power when its suppose to, look for the junction to have broken wires. Gene
Re: 92 Dakota died [Re: poorboy] #2559734
10/06/18 01:55 AM
10/06/18 01:55 AM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
ive replaced the fuel pump at least twice over the 23 years ive owned it,and ive replaced the crank sensor also over the years,it just DIED,no sputter,just like i shut the key off,i think but cant remember for sure that i looked at the wiring several years ago and it was fine,i ordered a new mopar crank sensor today.......we will see!!
Re: 92 Dakota died [Re: rhad] #2559745
10/06/18 02:32 AM
10/06/18 02:32 AM
fredericksburg virginia
mopwrd340 Offline
mopwrd340  Offline
I had one that would start up and die and some times it would fine it turned out to be a bad map sensor .
Re: 92 Dakota died [Re: mopwrd340] #2573730
11/04/18 02:16 AM
11/04/18 02:16 AM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
late update,replaced the crank sensor and thought it was fixed???,i used a genuine mopar part!,drove for a few miles and it died again,no sputter just wham its dead interesting thing,if i just shift to netural or park and crank it wont start,BUT if i turn the key off then back on and crank it starts,i replaced the ign switch and tumbler a while back,surely not a loose wire where it plugs into the switch???? i did splice the wires and plug that go to the switchmbut that was 20 yrs ago,i left the wires long and stuffed them down into the column,i suppose its possible one of them has rubbed bare and shorting out,tho that seems far fetched,i looked at the wiring harness junction several yrs ago and it was ok,dont have a code reader and cant count flashes as this is obd1 ,IF it has set a code??
i hate these search and destroy missions,anyone else have a problem like this?,i ran a wire years ago from the fuelpump to near the battery,i can make the pump run by touching the wire to the hot post of the battery
i know its a old truck with 348,000 miles but ive owned it since 95 and its my trusty backup that ill never sell
Re: 92 Dakota died [Re: rhad] #2573738
11/04/18 02:58 AM
11/04/18 02:58 AM
mopwrd340 Offline
mopwrd340  Offline
I had a 91 dakota that would die and not start turned out the wires in the fuel pump housing 2 of them at the top had broke and were barely touching and would move when the fuel was sloshing around in the tank is the check engine light on .
Re: 92 Dakota died [Re: mopwrd340] #2574251
11/05/18 02:49 AM
11/05/18 02:49 AM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
no CEL
Re: 92 Dakota died [Re: rhad] #2575205
11/07/18 07:47 AM
11/07/18 07:47 AM
mopwrd340 Offline
mopwrd340  Offline
Have you ever replaced the pickup in the distributor .
Re: 92 Dakota died [Re: mopwrd340] #2575702
11/08/18 02:40 AM
11/08/18 02:40 AM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
i looked at it some today and remembered that i replaced the ign switch just before this started,so upon wiggling the key a little it died,not sure thats it but i ordered a new switch and we will see in a few days
Re: 92 Dakota died [Re: rhad] #2578626
11/15/18 02:37 AM
11/15/18 02:37 AM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
i replaced the ign switch ,second day driving a few miles each time,no die!!!!!
Re: 92 Dakota died [Re: rhad] #2578645
11/15/18 04:48 AM
11/15/18 04:48 AM
All parts will die when you use them, some sooner than others shruggy work
How long are you shooting to use this truck?
It has given you good service in my opinion up
Re: 92 Dakota died [Re: rhad] #2578895
11/15/18 07:55 PM
11/15/18 07:55 PM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
FWIW, I have a 93 with 160K and it's been one of the most useful vehicles I have ever owned. So I watch threads like these with great interest.
I prefer the N bodies over the AN body ones any day of the week.
I wish LMC or someone would offer more parts for the N series.
Common sense is a flower that does not grow in everybody's garden
Re: 92 Dakota died [Re: Ron_M] #2579022
11/16/18 02:34 AM
11/16/18 02:34 AM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
i bought this truck in 95 it had 142000 on it now it has 348500 on it i will NEVER sell this truck,maybe they will bury me in it?,at almost 75 thats coming sooner than later!!
Re: 92 Dakota died [Re: rhad] #2579384
11/16/18 11:52 PM
11/16/18 11:52 PM
Kings Beach, CA
tahoechallenge Offline
Kings Beach, CA
I had a 92 Dakota that I put close to 200k on it (212 total). During that time I replaced two fuel pumps, one ignition coil, one idle air solenoid, and repaired corroded wiring below the fuse box on the left inner fender. All of those would cause the truck not to run.
