Cross ram or tunnel ram, undecided. #2556770
09/30/18 08:39 PM
09/30/18 08:39 PM
Pa. U.S.A.
moparborn Offline OP
Pa. U.S.A.
Okay so I am starting to build my big block Stroker, it's going to be a slow process, I figure two years from this coming spring.
I have acquired a dual quad tunnel ram like I am running now but I have also acquired long ram manifolds.
I know that going with the tunnel ram I have a lot of the work already done.
With the cross rams it would be a whole lot more work but I think it would be alot cooler.
What would be your constructive thoughts on it.
Oh yeah ,keep in mind that this will be another twin turbo setup.
Re: Cross ram or tunnel ram, undecided. [Re: moparborn] #2556812
09/30/18 11:12 PM
09/30/18 11:12 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
like these??
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Cross ram or tunnel ram, undecided. [Re: W.I.N. Racing] #2556814
09/30/18 11:16 PM
09/30/18 11:16 PM
Byron, NY
Byron, NY
had them both
'60 Willys CJ5
Re: Cross ram or tunnel ram, undecided. [Re: moparborn] #2556819
09/30/18 11:27 PM
09/30/18 11:27 PM
Pa. U.S.A.
Pa. U.S.A.
Yeppers.
I am running the turbos on a tunnel ram now,but always liked the cross ram setup.
Re: Cross ram or tunnel ram, undecided. [Re: moparborn] #2557049
10/01/18 02:44 PM
10/01/18 02:44 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
The longram would maybe be easier packaging and be able to be kept under hood. The tunnel Ram is way better for hp in a NA app and likely flows better, but since you’re going turbos, it probably doesn’t matter as much. The long ram would make better torque down low and likely help spool the turbos quicker. I’d also say for visual effect a twin turbo long ram would be pretty mind blowing. I’d go with long rams
Re: Cross ram or tunnel ram, undecided. [Re: moparborn] #2559928
10/06/18 04:19 PM
10/06/18 04:19 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The cross rams are cool but the flow is so terribly limited with them that I can't see it making any sense to not use the tunnel instead.
Re: Cross ram or tunnel ram, undecided. [Re: DaytonaTurbo] #2570097
10/27/18 04:18 AM
10/27/18 04:18 AM
iagree
I seemed to remember that Chrysler made three different versions(length of the inside of the runners) and none of them made peak HP above 4200 RPM back then shruggy
OP, on your deal if you want different then use the long rams, if you want power with a lot wider HP and torque band then the tunnel ram is the only one that makes since to me up work
Which brand tunnel ram do you have, not all of them are equal to each other
Re: Cross ram or tunnel ram, undecided. [Re: moparborn] #2570165
10/27/18 12:06 PM
10/27/18 12:06 PM
Pa. U.S.A.
Pa. U.S.A.
I agree with the difference between tunnel ram and the long Rams for hp, but considering it's a stroker with twin turbos,my rpm's will not be high.
I am not worried about every single horse and pound of torque I can get but I do want it to perform good.
Re: Cross ram or tunnel ram, undecided. [Re: moparborn] #2571651
10/30/18 04:03 PM
10/30/18 04:03 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I love cross rams & have run a couple of the years & still have an original magnesium cross ram that was all cut up for Super Stock racing by the back in the day Ray Barton mods. I decided to go with a tunnel ram on my latest build.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Cross ram or tunnel ram, undecided. [Re: Cab_Burge] #2571779
10/30/18 08:51 PM
10/30/18 08:51 PM
Byron, NY
Byron, NY
iagree
they made two...Long Ram 30" and Short Ram 15" peak tq on the long ram was at 2800rpm and I cant remember on the short ram...but it was higher shruggy
'60 Willys CJ5
Re: Cross ram or tunnel ram, undecided. [Re: W.I.N. Racing] #2572587
11/01/18 02:16 PM
11/01/18 02:16 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
iagree
3500/3600 for the 15 inch.
OP if you go Long ram, are you going Carb or injection ?
Back in the Mid 90s , mopar action had a write up on doing a injection set up with carb bodies, E-booger(Erinburg..not sure if that's spelled right)
My dad converted a short ram over to Injection setup similar to the one lap Valiant
Peak power rose up to about 5500.
W.I.N was your brown truck in MCG once ? or Mopar Muscle I think it was a photo of your truck that inspired my dad to put the short ram on his D100, article said something about using 2 Van brake booster to move the booster over far enough to clear the D-side carb.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Cross ram or tunnel ram, undecided. [Re: moparborn] #2572614
11/01/18 03:12 PM
11/01/18 03:12 PM
Pa. U.S.A.
Pa. U.S.A.
I will be running twin turbos to a pair of fitech throttle bodies.
Re: Cross ram or tunnel ram, undecided. [Re: moparborn] #2573095
11/02/18 04:30 PM
11/02/18 04:30 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I will be someday also....
