Cross ram or tunnel ram, undecided.
#2556770
09/30/18 08:39 PM
09/30/18 08:39 PM
Posts: 735 Pa. U.S.A.
moparborn
Pa. U.S.A.
Okay so I am starting to build my big block Stroker, it's going to be a slow process, I figure two years from this coming spring. I have acquired a dual quad tunnel ram like I am running now but I have also acquired long ram manifolds. I know that going with the tunnel ram I have a lot of the work already done. With the cross rams it would be a whole lot more work but I think it would be alot cooler. What would be your constructive thoughts on it. Oh yeah ,keep in mind that this will be another twin turbo setup.
Re: Cross ram or tunnel ram, undecided.
[Re: moparborn]
#2556812
09/30/18 11:12 PM
09/30/18 11:12 PM
Posts: 2,105 Byron, NY
W.I.N. Racing
Byron, NY
like these??
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#2556814
09/30/18 11:16 PM
09/30/18 11:16 PM
W.I.N. Racing
Byron, NY
[Re: moparborn]
#2557049
10/01/18 02:44 PM
10/01/18 02:44 PM
Posts: 4,254 Canada
WO23Coronet
Canada
The longram would maybe be easier packaging and be able to be kept under hood. The tunnel Ram is way better for hp in a NA app and likely flows better, but since you’re going turbos, it probably doesn’t matter as much. The long ram would make better torque down low and likely help spool the turbos quicker. I’d also say for visual effect a twin turbo long ram would be pretty mind blowing. I’d go with long rams
[Re: DaytonaTurbo]
#2570097
10/27/18 04:18 AM
10/27/18 04:18 AM
Posts: 43,119 Bend,OR USA
Cab_Burge
The cross rams are cool but the flow is so terribly limited with them that I can't see it making any sense to not use the tunnel instead. I seemed to remember that Chrysler made three different versions(length of the inside of the runners) and none of them made peak HP above 4200 RPM back then OP, on your deal if you want different then use the long rams, if you want power with a lot wider HP and torque band then the tunnel ram is the only one that makes since to me Which brand tunnel ram do you have, not all of them are equal to each other
[Re: moparborn]
#2571651
10/30/18 04:03 PM
10/30/18 04:03 PM
Posts: 4,563 Motor City
6PKRTSE
Motor City
I love cross rams & have run a couple of the years & still have an original magnesium cross ram that was all cut up for Super Stock racing by the back in the day Ray Barton mods. I decided to go with a tunnel ram on my latest build.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Cab_Burge]
#2571779
10/30/18 08:51 PM
10/30/18 08:51 PM
W.I.N. Racing
Byron, NY
The cross rams are cool but the flow is so terribly limited with them that I can't see it making any sense to not use the tunnel instead. I seemed to remember that Chrysler made three different versions(length of the inside of the runners) they made two...Long Ram 30" and Short Ram 15" peak tq on the long ram was at 2800rpm and I cant remember on the short ram...but it was higher
[Re: W.I.N. Racing]
#2572587
11/01/18 02:16 PM
11/01/18 02:16 PM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
The cross rams are cool but the flow is so terribly limited with them that I can't see it making any sense to not use the tunnel instead. I seemed to remember that Chrysler made three different versions(length of the inside of the runners) they made two...Long Ram 30" and Short Ram 15" peak tq on the long ram was at 2800rpm and I cant remember on the short ram...but it was higher 3500/3600 for the 15 inch. OP if you go Long ram, are you going Carb or injection ? Back in the Mid 90s , mopar action had a write up on doing a injection set up with carb bodies, E-booger(Erinburg..not sure if that's spelled right) My dad converted a short ram over to Injection setup similar to the one lap Valiant Peak power rose up to about 5500. W.I.N was your brown truck in MCG once ? or Mopar Muscle I think it was a photo of your truck that inspired my dad to put the short ram on his D100, article said something about using 2 Van brake booster to move the booster over far enough to clear the D-side carb.
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: moparborn]
#2573095
11/02/18 04:30 PM
11/02/18 04:30 PM
6PKRTSE
Motor City
I will be running twin turbos to a pair of fitech throttle bodies. I will be someday also....
