SB Victor head exhaust flanges, anybody need a set?
#2565822
10/18/18 10:54 AM
10/18/18 10:54 AM
Posts: 656 Florida
CJD AUTOMOTIVE
Getting ready to run a few sets of header flanges for the SB Victor head. Anybody interested in a set?
Craig Scholl CJD Automotive, LLC Jacksonville, FL www.CJDAUTOMOTIVE.com904-400-1802 "I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: SB Victor head exhaust flanges, anybody need a set?
[Re: Rob C]
#2565840
10/18/18 11:32 AM
10/18/18 11:32 AM
Posts: 20,169 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Can you message me a price. Just kinda window shopping now but who Knows. May be time to upgrade my 360-1’s
[Re: Rob C]
#2565965
10/18/18 03:05 PM
10/18/18 03:05 PM
Posts: 656 Florida
CJD AUTOMOTIVE
That looks cool.
Can you make/do you have W5 flanges? Is it possible to make a dual mounting flange? SDPexhaust already makes a CNC W5 flange, I think. http://www.spdexhaust.com/MoparB.html#
[Re: CJD AUTOMOTIVE]
#2565968
10/18/18 03:10 PM
10/18/18 03:10 PM
Posts: 656 Florida
CJD AUTOMOTIVE
If enough people wanted a cheaper flange, I can have them water jet cut. Same profile, but not chamfered and pretty like milling them.
[Re: scottb]
#2566042
10/18/18 05:35 PM
10/18/18 05:35 PM
Posts: 20,169 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Pretty does nothing for me. I kinda like cheap and fast. lol 😂
#2570897
10/29/18 11:19 AM
10/29/18 11:19 AM
Posts: 656 Florida
CJD AUTOMOTIVE
So I tweaked the design slightly. I got the print from Edelbrock for the head, but turns out it's the print for the gasket. This is the same print that the Stainless Headers flange is made from. While the bolt hole and port locations are all correct, it uses a round port on the D shaped port. I've scanned the port and enlarged it by the wall thickness of the tube material (.070). Now the stub can be formed to the shape with an almost perfect transition to round. The port area is slightly smaller than 1-7/8" ID tubing, and slightly larger than 1-3/4" ID tubing in 16 gauge. I'm having some 304 SS flanges water jet cut this week. Will post them when I get them.
#2570900
10/29/18 11:22 AM
10/29/18 11:22 AM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
Its not listed on the site that they do.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
#2571184
10/29/18 07:38 PM
10/29/18 07:38 PM
Posts: 656 Florida
CJD AUTOMOTIVE
I'm calling these good for water jet. I can make more, but need a few sets to be worth while and all need to be the same, 3/8", 1/2", etc...
[Re: slowfab]
#2571217
10/29/18 08:27 PM
10/29/18 08:27 PM
Posts: 656 Florida
CJD AUTOMOTIVE
I am in the market for a set in Stainless for a turbo setup. The ones pictured are 1/2" 304 SS for a turbo application. I'm machining a set, so will sell these when done using them for mockup.
#2571774
10/30/18 08:46 PM
10/30/18 08:46 PM
Posts: 656 Florida
CJD AUTOMOTIVE
#2571775
10/30/18 08:47 PM
10/30/18 08:47 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Pretty happy with the transition: Okay, lets lay out some headers!
#2576396
11/09/18 03:33 PM
11/09/18 03:33 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Thanks. I have played this out about 10 times now! Got to clear a 335" front tire at full lock, steering, A-arm, coil over, let me remove valve covers, access spark plugs,....and need it to come out between the firewall and tire to mate with the turbo, all with very long primaries... The "lego's" definitely earned there money.
#2576586
11/09/18 11:46 PM
11/09/18 11:46 PM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
CJD, tell us about that Stef's oil pan...those "legos" are pretty cool. Where do you get those. Very nice work.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
[Re: mopardude318]
#2580770
11/20/18 08:53 PM
11/20/18 08:53 PM
Posts: 656 Florida
CJD AUTOMOTIVE
CJD, tell us about that Stef's oil pan...those "legos" are pretty cool. Where do you get those. Very nice work. Sorry, just saw this. The kits are available from Summit, Jegs, Trick-tools, etc. Summit and a coupon is your friend on these! The Stef's pan is a dry sump I had them built. The 3 scavenges are on the P-side. That fitting on the drivers, in the pic, is the turbo oil drain. I had Stef's build it because they were the only ones putting piston oilers in the pan. Got it back, and no oilers. Said they don't do that anymore. Very pissed. Put the BLP jets in the block instead.
[Re: Biginchmopar]
#2581215
11/21/18 07:08 PM
11/21/18 07:08 PM
Posts: 656 Florida
CJD AUTOMOTIVE
