More 360-1 head questions #2570656
10/28/18 05:10 PM
10/28/18 05:10 PM
Seaford, Va
Kindafast Offline OP
Seaford, Va
Hey guys I plan on getting my heads ported and polished by someone but not too sure who yet so any references would be appreciated. Also I have a few questions about fitment. Like would my old Stock style TTI headers headers fit or is there an adapter to use so I don't have to purchase a new set ? I have a well worked and ported M1 intake now but what is the best ? I know I am getting the Indy one with the deal also. Any and all advice would be appreciated..
6.50 @105.26
Re: More 360-1 head questions [Re: Kindafast] #2570659
10/28/18 05:22 PM
10/28/18 05:22 PM
bronx n.y
O
one bad fish Offline
O
bronx n.y
get them Cnc from Indy
Re: More 360-1 head questions [Re: Kindafast] #2570661
10/28/18 05:26 PM
10/28/18 05:26 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Use Brett Miller or Brian at IMM to port your heads. Its easy to grind through on the Indys.
I made adapter plates to make my hooker adj work for me. but they have a 4 bolt flange. You might have to cut your flanges and weld new ones.
The indy intake is the best for those heads and you might want to have it ported by who ever does your heads
Re: More 360-1 head questions [Re: DavidDean] #2570664
10/28/18 05:34 PM
10/28/18 05:34 PM
bronx n.y
O
O
bronx n.y
true
Re: More 360-1 head questions [Re: Kindafast] #2570670
10/28/18 06:01 PM
10/28/18 06:01 PM
Seaford, Va
Seaford, Va
How do I get in touch with Brett Miller ? I know Brian at IMM is in Southern California right ?
6.50 @105.26
Re: More 360-1 head questions [Re: Kindafast] #2570671
10/28/18 06:06 PM
10/28/18 06:06 PM
bronx n.y
O
O
bronx n.y
Brett is on here
Re: More 360-1 head questions [Re: one bad fish] #2570677
10/28/18 06:53 PM
10/28/18 06:53 PM
Seaford, Va
Seaford, Va
Brett is on here
Great , can you give me his name on here or let him know I would like to talk ? Thanks
6.50 @105.26
Re: More 360-1 head questions [Re: Kindafast] #2570681
10/28/18 07:16 PM
10/28/18 07:16 PM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
http://www.shadydellspeedshop.com/indyheads.htm
Ryan would be the guy to go to has done more indys than anyone
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: More 360-1 head questions [Re: Kindafast] #2570776
10/28/18 11:00 PM
10/28/18 11:00 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
I’d call Ryan at shady dell
Re: More 360-1 head questions [Re: Kindafast] #2570810
10/28/18 11:57 PM
10/28/18 11:57 PM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
Brett is on here
Brett's name on here is W5DART66 He is on an active thread on here now about a 457" W9 pump gas motor. You can PM him.
Re: More 360-1 head questions [Re: b1dartsport] #2570820
10/29/18 12:31 AM
10/29/18 12:31 AM
PA
W5DART66 Offline
W5DART66  Offline
PA
Thanks for the recommendation on me porting the indys.
The way to go is get Indy to CNC them only and get a good shop to valve job them and blend.
The Indy CNC port can make good power and most of the hand port stuff has not been that good. (Most I would call shine job ) sand roll and make you feel good about spending your money.
Water to close in the short turn to really get after this head.
If yours are as cast the Indy program will be a big improvement.
Some work on the intake will help also if it's as cast.
Re: More 360-1 head questions [Re: W5DART66] #2570848
10/29/18 02:35 AM
10/29/18 02:35 AM
SoCal
Brian Hafliger Offline
SoCal
Ask David Dean about our hand porting on Indy heads
Brian Hafliger
Re: More 360-1 head questions [Re: Kindafast] #2570868
10/29/18 07:42 AM
10/29/18 07:42 AM
Seaford, Va
Seaford, Va
Hey guys thanks for the replies.. The CNC idea sounds really good but I hate dealing with INDY due to the attitude. Brett I will message you if that's okay . I spoke with Ryan at Shady Dell and he states that he can do the heads with a CNC machine also. "Ou812" I have seen and heard of your work and the numbers are great. If you were closer we sure would talk.
6.50 @105.26
Re: More 360-1 head questions [Re: Kindafast] #2571003
10/29/18 02:22 PM
10/29/18 02:22 PM
Washington
madscientist Offline
Washington
The brown truck goes everywhere. I wouldn't let geography pick my head guy.
I will say I have not personally seen ANY head that was CNC ported that I would run. Not a single one. They all need some finish work.
Re: More 360-1 head questions [Re: madscientist] #2571024
10/29/18 02:58 PM
10/29/18 02:58 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
Couldnt agree more. In the overall cost of doing a build an extra 100 or two involved in shipping those heads to a guy like Brian i wouldnt think a second about.
I know a poster on here named David Dean has been 120 in the 1/8 with Indy heads IMM did. To me thats ultra impressive
I have heard of Indy CNC heads leaking just from having theyre CNC run on them.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: More 360-1 head questions [Re: madscientist] #2571027
10/29/18 03:01 PM
10/29/18 03:01 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I will say I have not personally seen ANY head that was CNC ported that I would run. Not a single one. They all need some finish work. [/quote]
I couldn't agree with you more there about CNC'd heads and read to many nightmare stories about Indy not standing behind their work. As far as shipping stuff that's the main reason I never took on more porting work. I used to charge 500-600 to port heads and 150.00 for intakes. It was local carry in work that they could drop off and pay after the work was finished. Living in the Country I didn't want bothered with driving the 20 mile trip to ship stuff and box it up. Some of the CNC'd stuff I've checked on my bench would have you shaking your head. I know I did.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: More 360-1 head questions [Re: Brian Hafliger] #2571074
10/29/18 04:42 PM
10/29/18 04:42 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Yeah they work Damn Good ! They've been 5.66 @ 123 in my duster.
Re: More 360-1 head questions [Re: DavidDean] #2571088
10/29/18 05:05 PM
10/29/18 05:05 PM
Seaford, Va
Seaford, Va
Wow !!!
6.50 @105.26
Re: More 360-1 head questions [Re: DavidDean] #2571089
10/29/18 05:08 PM
10/29/18 05:08 PM
bronx n.y
O
O
bronx n.y
on motor
Re: More 360-1 head questions [Re: Kindafast] #2571137
10/29/18 06:25 PM
10/29/18 06:25 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
YES, I run methanol
