9 sec. Pump gas, N/A small block #2570196
10/27/18 01:57 PM
10/27/18 01:57 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Only limiters being have to run pump gas (no E85) and not in a rail car or other 2000lb tin can, how would you (or better yet, how HAVE you) build it???
Doesnt have to be deep in the 9's, but a solid pass after pass 9 second ride (in the 1/4 mile of course lol)
Re: 9 sec. Pump gas, N/A small block [Re: mshred] #2570199
10/27/18 02:02 PM
10/27/18 02:02 PM
bronx n.y
O
one bad fish Offline
O
bronx n.y
its definitely do able
Re: 9 sec. Pump gas, N/A small block [Re: mshred] #2570210
10/27/18 02:29 PM
10/27/18 02:29 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Goes without saying but...the lighter the car, the less difficult and expensive it would be on the motor side.
A 3000lb A body, is going to require a HUGE difference in motor compared to a 3700lb b pr e body.
Re: 9 sec. Pump gas, N/A small block [Re: dizuster] #2570223
10/27/18 02:56 PM
10/27/18 02:56 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I’m thinking it would be very doable but a project I have zero interest in. My sons stock crank 360 has gone several 6.54’s in the 1/8 (3200 pounds) which would be 10.20-10.30’s in the 1/4. It’s on alcohol but with pump gas compression and even with the less desired open chamber 340 style Edelbrock heads. The small 600 lift roller cam is missing out on the 318 cfm @ .700’lift these heads put out. I would also step up his 4.10 gear slightly in place of his 750 alcohol carb a 1050 dominator would be tried. The heads would be cut for better quench for sure for BP 93. My Duster although a light weight (2820 at the time) easily went 9.80’s on pump gas BP 93 with a mildly ported set of W2 heads and a mild roller cam. A nice ported set of 360-1 heads, ported indy intake, and a nice roller cam packaged in a Stroker engine should be a cake walk on pump junk.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 9 sec. Pump gas, N/A small block [Re: mshred] #2570233
10/27/18 03:12 PM
10/27/18 03:12 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Any limits on cubic inch?
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: 9 sec. Pump gas, N/A small block [Re: mshred] #2570237
10/27/18 03:24 PM
10/27/18 03:24 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
I am doing it now with W5 heads. 9.67-9.70
Re: 9 sec. Pump gas, N/A small block [Re: Sammy] #2570246
10/27/18 03:46 PM
10/27/18 03:46 PM
bronx n.y
O
O
bronx n.y
what does the car weigh
Re: 9 sec. Pump gas, N/A small block [Re: mshred] #2570256
10/27/18 04:07 PM
10/27/18 04:07 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
What the specs on the engine
Re: 9 sec. Pump gas, N/A small block [Re: ric3xrt] #2570260
10/27/18 04:17 PM
10/27/18 04:17 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Nope! Just like the original post says, must be pump fuel (not e85) and not a rail car and has to be n/a
Lighter Weight for sure makes things easier on parts, but still curious to hear the combos out there
Re: 9 sec. Pump gas, N/A small block [Re: Sammy] #2570261
10/27/18 04:18 PM
10/27/18 04:18 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Definitely know guys are doing it, was looking to maybe have some share a bit about the combo they have if they are doing it
Re: 9 sec. Pump gas, N/A small block [Re: mshred] #2570264
10/27/18 04:22 PM
10/27/18 04:22 PM
PA.
"Little"John
"Little"John
PA.
Are you going to park that motorcycle and get the car back out again?
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: 9 sec. Pump gas, N/A small block [Re: mshred] #2570271
10/27/18 04:49 PM
10/27/18 04:49 PM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
By N/A, you mean "Nitrous Assisted"...right?
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: 9 sec. Pump gas, N/A small block [Re: mshred] #2570274
10/27/18 04:54 PM
10/27/18 04:54 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Eazy Peezy with a G3 Hemi at 3000lbs...
Re: 9 sec. Pump gas, N/A small block [Re: pittsburghracer] #2570276
10/27/18 05:00 PM
10/27/18 05:00 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Who said this post is about me? Just curious, ya know?
Re: 9 sec. Pump gas, N/A small block [Re: Dragula] #2570277
10/27/18 05:01 PM
10/27/18 05:01 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Hmmmmmm, I dunno about that...I'd need to see more examples that prove it without any power adders
Re: 9 sec. Pump gas, N/A small block [Re: mshred] #2570278
10/27/18 05:04 PM
10/27/18 05:04 PM
Seaford, Va
Kindafast Offline
Kindafast  Offline
Seaford, Va
I am hoping to give it a try. I posted about heads in another post and I am really looking for a high 9 second pass. I always run pump gas on my stuff. Flat top 4.10 bore 4" crank. I had open Eddie heads before but now going with the Indy 360-1s and some porting. Roller 6.56 cam and a 950 HP carb.. Oh yea a 8.75 rear end " LOL
6.50 @105.26
Re: 9 sec. Pump gas, N/A small block [Re: Dragula] #2570287
10/27/18 05:28 PM
10/27/18 05:28 PM
PA.
"Little"John
"Little"John
PA.
Lol 😂. Yaaaaa right.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: 9 sec. Pump gas, N/A small block [Re: mshred] #2570291
10/27/18 05:50 PM
10/27/18 05:50 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Ray(Sixpackgut) ran into the 9.7s I believe on drag week with a 428" Gen III at 3200lbs pump fuel.
68 Barracuda Formula S 340
Re: 9 sec. Pump gas, N/A small block [Re: Bad340fish] #2570293
10/27/18 06:00 PM
10/27/18 06:00 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
My 2009 engine masters motor went 9.60s in a street car 140mph 3100lbs 396"
That engine made 660 HP at 7000 rpm
Still running in a D50 down south drives it to the track.
Second car was Brads 422" w9 motor
Was built for spray and we went 9.40s on pump gas 140mph
3150 lbs
I don't feel it's hard to run mid 9s in 2900-3100 lbs car. On pump gas
The pump gas 457" deal I just did should run low 9s
Re: 9 sec. Pump gas, N/A small block [Re: Bad340fish] #2570295
10/27/18 06:04 PM
10/27/18 06:04 PM
Dragula Offline
Dragula  Offline
Bingo...Drives it 1000 miles and runs 9.80's on pump gas. He has posted his combo on here, and it runs the number.
