Re: 9 sec. Pump gas, N/A small block
[Re: mshred]
#2570199
10/27/18 02:02 PM
10/27/18 02:02 PM
Posts: 1,534 bronx n.y
one bad fish
bronx n.y
Only limiters being have to run pump gas (no E85) and not in a rail car or other 2000lb tin can, how would you (or better yet, how HAVE you) build it???
Doesnt have to be deep in the 9's, but a solid pass after pass 9 second ride (in the 1/4 mile of course lol) its definitely do able
[Re: dizuster]
#2570223
10/27/18 02:56 PM
10/27/18 02:56 PM
Posts: 20,178 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I’m thinking it would be very doable but a project I have zero interest in. My sons stock crank 360 has gone several 6.54’s in the 1/8 (3200 pounds) which would be 10.20-10.30’s in the 1/4. It’s on alcohol but with pump gas compression and even with the less desired open chamber 340 style Edelbrock heads. The small 600 lift roller cam is missing out on the 318 cfm @ .700’lift these heads put out. I would also step up his 4.10 gear slightly in place of his 750 alcohol carb a 1050 dominator would be tried. The heads would be cut for better quench for sure for BP 93. My Duster although a light weight (2820 at the time) easily went 9.80’s on pump gas BP 93 with a mildly ported set of W2 heads and a mild roller cam. A nice ported set of 360-1 heads, ported indy intake, and a nice roller cam packaged in a Stroker engine should be a cake walk on pump junk.
[Re: mshred]
#2570233
10/27/18 03:12 PM
10/27/18 03:12 PM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
Any limits on cubic inch?
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: Sammy]
#2570246
10/27/18 03:46 PM
10/27/18 03:46 PM
one bad fish
bronx n.y
I am doing it now with W5 heads. 9.67-9.70 what does the car weigh
[Re: ric3xrt]
#2570260
10/27/18 04:17 PM
10/27/18 04:17 PM
Posts: 3,415 Toronto
mshred
Toronto
Any limits on cubic inch? Nope! Just like the original post says, must be pump fuel (not e85) and not a rail car and has to be n/a Lighter Weight for sure makes things easier on parts, but still curious to hear the combos out there
[Re: Sammy]
#2570261
10/27/18 04:18 PM
10/27/18 04:18 PM
mshred
Toronto
I am doing it now with W5 heads. 9.67-9.70 Definitely know guys are doing it, was looking to maybe have some share a bit about the combo they have if they are doing it
[Re: mshred]
#2570264
10/27/18 04:22 PM
10/27/18 04:22 PM
Posts: 20,178 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I am doing it now with W5 heads. 9.67-9.70 Definitely know guys are doing it, was looking to maybe have some share a bit about the combo they have if they are doing it Are you going to park that motorcycle and get the car back out again?
[Re: mshred]
#2570271
10/27/18 04:49 PM
10/27/18 04:49 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
By N/A, you mean "Nitrous Assisted"...right?
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: pittsburghracer]
#2570276
10/27/18 05:00 PM
10/27/18 05:00 PM
mshred
Toronto
I am doing it now with W5 heads. 9.67-9.70 Definitely know guys are doing it, was looking to maybe have some share a bit about the combo they have if they are doing it Are you going to park that motorcycle and get the car back out again? Who said this post is about me? Just curious, ya know?
[Re: Dragula]
#2570277
10/27/18 05:01 PM
10/27/18 05:01 PM
mshred
Toronto
Eazy Peezy with a G3 Hemi at 3000lbs... Hmmmmmm, I dunno about that...I'd need to see more examples that prove it without any power adders
[Re: mshred]
#2570278
10/27/18 05:04 PM
10/27/18 05:04 PM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
I am hoping to give it a try. I posted about heads in another post and I am really looking for a high 9 second pass. I always run pump gas on my stuff. Flat top 4.10 bore 4" crank. I had open Eddie heads before but now going with the Indy 360-1s and some porting. Roller 6.56 cam and a 950 HP carb.. Oh yea a 8.75 rear end " LOL
6.50 @105.26
[Re: Dragula]
#2570287
10/27/18 05:28 PM
10/27/18 05:28 PM
Posts: 20,178 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Eazy Peezy with a G3 Hemi at 3000lbs... Lol 😂. Yaaaaa right.
[Re: mshred]
#2570291
10/27/18 05:50 PM
10/27/18 05:50 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
Eazy Peezy with a G3 Hemi at 3000lbs... Hmmmmmm, I dunno about that...I'd need to see more examples that prove it without any power adders Ray(Sixpackgut) ran into the 9.7s I believe on drag week with a 428" Gen III at 3200lbs pump fuel.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2570295
10/27/18 06:04 PM
10/27/18 06:04 PM
Posts: 12,391 Taxes & Virus's R-US, NY
Dragula
Eazy Peezy with a G3 Hemi at 3000lbs... Hmmmmmm, I dunno about that...I'd need to see more examples that prove it without any power adders Ray(Sixpackgut) ran into the 9.7s I believe on drag week with a 428" Gen III at 3200lbs pump fuel. Bingo...Drives it 1000 miles and runs 9.80's on pump gas. He has posted his combo on here, and it runs the number.
