457" pump gas w9 motor. #2569969
10/26/18 10:31 PM
10/26/18 10:31 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Re: 457" pump gas w9 motor. [Re: W5DART66] #2570030
10/27/18 12:09 AM
10/27/18 12:09 AM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Re: 457" pump gas w9 motor. [Re: W5DART66] #2570031
10/27/18 12:21 AM
10/27/18 12:21 AM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Latest Ritter block
Molnar crank and Rods
Custom icon pistons
11.6 to1
4.200" bore
4.125" stroke
1050 4500 carb.
60mm cam
My w9 CNC program
Steel 2.15" in. 1.60" exhaust.
Tall deck Mopar intake with not much work was done before I got the stuff from engine owner.
Started out with know good carb on race gas
Just switched over to pump gas tonight.
811 HP
670 TQ on race fuel and a good 1150 (did not try to beat on race gas tune)
That was just to make sure it's all good.
Best pull on pump gas so far 804 660.
Re: 457" pump gas w9 motor. [Re: W5DART66] #2570094
10/27/18 03:55 AM
10/27/18 03:55 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Awesome numbers,are the W9s max effort ?
Re: 457" pump gas w9 motor. [Re: W5DART66] #2570101
10/27/18 05:31 AM
10/27/18 05:31 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Any issues with the Ritter block? wave
Re: 457" pump gas w9 motor. [Re: W5DART66] #2570105
10/27/18 06:58 AM
10/27/18 06:58 AM
gregsdart Offline
gregsdart  Offline
Wow! Great build! Looks like for best ET you could keep the rpm below 7500 rpm? What are the head flow numbers?
Re: 457" pump gas w9 motor. [Re: W5DART66] #2570109
10/27/18 07:10 AM
10/27/18 07:10 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
That is awesome!
Re: 457" pump gas w9 motor. [Re: LAD 524] #2570116
10/27/18 08:43 AM
10/27/18 08:43 AM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
No far from max type deal.
It's my small intake port and not the size or type of valve I would use for max effort deal.
Only 2.15" intake valve and they are steel.
This was as budget as we could be so as much as I could use from what he had I did.
Re: 457" pump gas w9 motor. [Re: gregsdart] #2570119
10/27/18 08:49 AM
10/27/18 08:49 AM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Yes I think 7500 will be the shift point power is still good at 7500.
Did not flow heads but have done so many w9s they would be in the 360-370 range
Exhaust would be in the 250s
This has small 2.15 intake valve and exhaust valve with wrong shape.
45° valve seats. (Not what I normally use on w9) but locked into using valves and no margin to change seat angle.
Re: 457" pump gas w9 motor. [Re: W5DART66] #2570134
10/27/18 10:29 AM
10/27/18 10:29 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
What minimum & average CSAs does your "small" port have?
Any more details about the cam you can provide?
Re: 457" pump gas w9 motor. [Re: W5DART66] #2570151
10/27/18 11:25 AM
10/27/18 11:25 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Take my money! Now!
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: 457" pump gas w9 motor. [Re: W5DART66] #2570158
10/27/18 11:37 AM
10/27/18 11:37 AM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
Wow. Heck yes. I want a Ritter block too!
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: 457" pump gas w9 motor. [Re: W5DART66] #2570179
10/27/18 01:20 PM
10/27/18 01:20 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Another great SB build,
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: 457" pump gas w9 motor. [Re: W5DART66] #2570181
10/27/18 01:23 PM
10/27/18 01:23 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Nice Work Bret, would this power level work ok without the extra head bolts? I have a 59* R1 in my car with the extra bosses milled off.
68 Barracuda Formula S 340
Re: 457" pump gas w9 motor. [Re: Bad340fish] #2570213
10/27/18 02:44 PM
10/27/18 02:44 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Yea no problem
To get this power with the smaller bore your block will take have to go at it little different.
Re: 457" pump gas w9 motor. [Re: W5DART66] #2570226
10/27/18 03:00 PM
10/27/18 03:00 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
up Nice!
72 Plymouth Roadrunner 11.08@123.25
Re: 457" pump gas w9 motor. [Re: W5DART66] #2570460
10/28/18 02:21 AM
10/28/18 02:21 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Very cool. This raises the bar some.
Re: 457" pump gas w9 motor. [Re: BradH] #2570512
10/28/18 10:14 AM
10/28/18 10:14 AM
BradH Offline
BradH  Offline
Hmmmm... no response. Does this mean I'll have to ask you at Carlisle next year after you frisk me to make sure I'm not recording the conversation? laugh2
Also, you mentioned custom Icon pistons... as in directly from the manufacturer, or modified by someone else? Only asking because I thought they didn't offer anything except their stocking pistons.
Re: 457" pump gas w9 motor. [Re: BradH] #2570527
10/28/18 11:18 AM
10/28/18 11:18 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Brett is pretty secretive. He will post up some jewelry on Facebook and then disappear. I made a comment about the deep valve pockets and he posted back he did that to lower the compression. I was kinda surprised by the sharp edges left and was always led to believe edges should be slightly radiased. Looks like a nice combo that won’t have to be shifted as high as some of the W9 stuff.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 457" pump gas w9 motor. [Re: pittsburghracer] #2570537
10/28/18 11:47 AM
10/28/18 11:47 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
By the looks of the dyno numbers everything was just right 800 hp. On pump junk wow great job.. wrench
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
