457" pump gas w9 motor.
#2569969
10/26/18 10:31 PM
10/26/18 10:31 PM
Posts: 1,784 PA
W5DART66
PA
Re: 457" pump gas w9 motor.
[Re: W5DART66]
#2570030
10/27/18 12:09 AM
10/27/18 12:09 AM
Posts: 1,784 PA
W5DART66
PA
[Re: gregsdart]
#2570119
10/27/18 08:49 AM
10/27/18 08:49 AM
Posts: 1,784 PA
W5DART66
PA
Wow! Great build! Looks like for best ET you could keep the rpm below 7500 rpm? What are the head flow numbers? Yes I think 7500 will be the shift point power is still good at 7500. Did not flow heads but have done so many w9s they would be in the 360-370 range Exhaust would be in the 250s This has small 2.15 intake valve and exhaust valve with wrong shape. 45° valve seats. (Not what I normally use on w9) but locked into using valves and no margin to change seat angle.
[Re: W5DART66]
#2570134
10/27/18 10:29 AM
10/27/18 10:29 AM
BradH
It's my small intake port and not the size or type of valve I would use for max effort deal. Only 2.15" intake valve and they are steel.
What minimum & average CSAs does your "small" port have? Any more details about the cam you can provide?
[Re: W5DART66]
#2570158
10/27/18 11:37 AM
10/27/18 11:37 AM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
Wow. Heck yes. I want a Ritter block too!
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
[Re: W5DART66]
#2570181
10/27/18 01:23 PM
10/27/18 01:23 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
Nice Work Bret, would this power level work ok without the extra head bolts? I have a 59* R1 in my car with the extra bosses milled off.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2570213
10/27/18 02:44 PM
10/27/18 02:44 PM
Posts: 1,784 PA
W5DART66
PA
Nice Work Bret, would this power level work ok without the extra head bolts? I have a 59* R1 in my car with the extra bosses milled off. Yea no problem To get this power with the smaller bore your block will take have to go at it little different.
[Re: BradH]
#2570512
10/28/18 10:14 AM
10/28/18 10:14 AM
BradH
What minimum & average CSAs does your "small" port have? Any more details about the cam you can provide? Hmmmm... no response. Does this mean I'll have to ask you at Carlisle next year after you frisk me to make sure I'm not recording the conversation? Also, you mentioned custom Icon pistons... as in directly from the manufacturer, or modified by someone else? Only asking because I thought they didn't offer anything except their stocking pistons.
[Re: BradH]
#2570527
10/28/18 11:18 AM
10/28/18 11:18 AM
Posts: 20,178 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Brett is pretty secretive. He will post up some jewelry on Facebook and then disappear. I made a comment about the deep valve pockets and he posted back he did that to lower the compression. I was kinda surprised by the sharp edges left and was always led to believe edges should be slightly radiased. Looks like a nice combo that won’t have to be shifted as high as some of the W9 stuff.
