Griner t/brake UPDATE #2568782
10/24/18 11:51 AM
10/24/18 11:51 AM
Mesa, AZ
cagebob1 Offline OP
cagebob1  Offline OP
Mesa, AZ
My Griner LBA brake sometimes won't hold the car on the starting line. Sometimes it works OK. Always feels like it engages, but sometimes the car will roll thru the beams.
Where do I start the diagnostics?
bow
Re: Griner t/brake [Re: cagebob1] #2568817
10/24/18 12:35 PM
10/24/18 12:35 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Check your line pressure. My 904 is about 175. I dont remember what a 727 is off the top of my head.
Re: Griner t/brake [Re: cagebob1] #2568818
10/24/18 12:39 PM
10/24/18 12:39 PM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
do you bring it up to 2000 rpm when you stage
Re: Griner t/brake [Re: cagebob1] #2568838
10/24/18 01:10 PM
10/24/18 01:10 PM
fla
ss/la Offline
ss/la  Offline
fla
check your rear band adjustment
Re: Griner t/brake [Re: ss/la] #2568888
10/24/18 02:22 PM
10/24/18 02:22 PM
Mesa, AZ
cagebob1 Offline OP
cagebob1  Offline OP
Mesa, AZ
yes, I stage it at 2000 rpms or a little more. Please keep the suggestions coming.
bow
Re: Griner t/brake [Re: cagebob1] #2568902
10/24/18 02:42 PM
10/24/18 02:42 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Mine engaged just off idle (1100-1200)
Something else going if it takes 2k and still sometimes doesnt hold
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Griner t/brake [Re: cagebob1] #2568912
10/24/18 02:55 PM
10/24/18 02:55 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
High clutch slipping. High gear ok?
Re: Griner t/brake [Re: cagebob1] #2569095
10/24/18 08:32 PM
10/24/18 08:32 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I had trouble with mine once. It was shifter cable adjustment.
Re: Griner t/brake [Re: cagebob1] #2569119
10/24/18 09:23 PM
10/24/18 09:23 PM
A727Tflite Offline
A727Tflite  Offline
Check the switch for resistance - make sure wiring is not damaged.
Had a Turbo Action unit do the same and the switch was bad.
Re: Griner t/brake [Re: CMcAllister] #2569179
10/24/18 11:51 PM
10/24/18 11:51 PM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
This is correct.
How long do you have on the trans? Has this been a problem since day one?
My 904 would occasionally do this with a Griner LBA Brake. later it wouln't hold at WOT and I had to chip it down. Eventually high gear failed. We tightened up the High gear clutch pack clearance on rebuild, and added 1 1/2 turns of pressure. Never had a problem in the 5 years since.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Griner t/brake [Re: MoparBilly] #2569329
10/25/18 12:48 PM
10/25/18 12:48 PM
Mesa, AZ
cagebob1 Offline OP
cagebob1  Offline OP
Mesa, AZ
Thanks for all of the input! looks like I have a few things to check. Any more suggestions are welcome.
bow
Re: Griner t/brake [Re: cagebob1] #2569586
10/26/18 12:13 AM
10/26/18 12:13 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Whenever I’d get creep with my Griner I knew it was freshen time. More times than not the teflon seals I use on the reaction shaft support we’re going away. Fresh trans would lock at 1000rpm
Re: Griner t/brake UPDATE [Re: cagebob1] #2573531
11/03/18 06:12 PM
11/03/18 06:12 PM
Mesa, AZ
cagebob1 Offline OP
cagebob1  Offline OP
Mesa, AZ
OK, Maybe I really am as dumb as a box of hair! I just tryed checking my line pressure at the center port on the pass side .... no pressure in any gear!
Where do you check line pressure with this valve body?
bow
Re: Griner t/brake UPDATE [Re: cagebob1] #2573537
11/03/18 06:23 PM
11/03/18 06:23 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Most current transbrake VB's have the center pressure tap blocked off, only way to check line pressure is at the front tap with the trans in high gear.
Re: Griner t/brake UPDATE [Re: John_Kunkel] #2573538
11/03/18 06:29 PM
11/03/18 06:29 PM
Mesa, AZ
cagebob1 Offline OP
cagebob1  Offline OP
Mesa, AZ
I was getting ready to try that and see what happens. Thank you for your assistance.
bow
Re: Griner t/brake UPDATE [Re: cagebob1] #2575500
11/07/18 07:51 PM
11/07/18 07:51 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
reverse servo with brake on should be 180lbs
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Griner t/brake UPDATE [Re: 440lebaron] #2575506
11/07/18 08:01 PM
11/07/18 08:01 PM
Mesa, AZ
cagebob1 Offline OP
cagebob1  Offline OP
Mesa, AZ
Another thing to check ... good to know! Haven't had much time recently ... plumbing problems in the house. panic
bow
Re: Griner t/brake UPDATE [Re: cagebob1] #2579923
11/18/18 06:45 PM
11/18/18 06:45 PM
Mesa, AZ
cagebob1 Offline OP
cagebob1  Offline OP
Mesa, AZ
Finally got a chance to look at this. The pressure in the rear servo is about 135psi in low gear, then drops to about 125psi with the brake engaged. Will turning up the pressure fix this? or do I have a deeper problem that is going to require trans disassembly and inspection? As always, thank you for your assistance.
bow
Re: Griner t/brake UPDATE [Re: cagebob1] #2582368
11/24/18 02:16 PM
11/24/18 02:16 PM
Mesa, AZ
cagebob1 Offline OP
cagebob1  Offline OP
Mesa, AZ
Thought I would update this, just in case anyone else is a nube to the transbrake world. Turned the line pressure up to 165 lbs, seemed to cure the holding problem ... but I think another problem has reared it's ugly head. engaging the transbrake causes line pressure in the rear servo to drop to 75 psi. Am I correct in assuming that there is a problem in the front drum/clutchpack? Could it be in the rear clutchpack? Guidance is always appreciated.
bow
Re: Griner t/brake UPDATE [Re: cagebob1] #2586730
12/03/18 07:37 PM
12/03/18 07:37 PM
Mesa, AZ
cagebob1 Offline OP
cagebob1  Offline OP
Mesa, AZ
"reverse servo with brake on should be 180lbs"
Are we still talking about a 727 ? I've seen those numbers tossed about for a glide.
Any and all input is welcome
bow
