Griner t/brake UPDATE
#2568782
10/24/18 11:51 AM
10/24/18 11:51 AM
Posts: 304 Mesa, AZ
cagebob1
Mesa, AZ
My Griner LBA brake sometimes won't hold the car on the starting line. Sometimes it works OK. Always feels like it engages, but sometimes the car will roll thru the beams. Where do I start the diagnostics?
Re: Griner t/brake
[Re: cagebob1]
#2568902
10/24/18 02:42 PM
10/24/18 02:42 PM
Posts: 11,705 Portage,michigan
B3422W5
Portage,michigan
Mine engaged just off idle (1100-1200) Something else going if it takes 2k and still sometimes doesnt hold
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: Griner t/brake
[Re: cagebob1]
#2569095
10/24/18 08:32 PM
10/24/18 08:32 PM
Posts: 20,158 Park Forest, IL
slantzilla
Park Forest, IL
I had trouble with mine once. It was shifter cable adjustment.
Re: Griner t/brake
[Re: CMcAllister]
#2569179
10/24/18 11:51 PM
10/24/18 11:51 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
High clutch slipping. High gear ok? This is correct. How long do you have on the trans? Has this been a problem since day one? My 904 would occasionally do this with a Griner LBA Brake. later it wouln't hold at WOT and I had to chip it down. Eventually high gear failed. We tightened up the High gear clutch pack clearance on rebuild, and added 1 1/2 turns of pressure. Never had a problem in the 5 years since.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
Re: Griner t/brake UPDATE
[Re: cagebob1]
#2573537
11/03/18 06:23 PM
11/03/18 06:23 PM
Posts: 25,729 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Most current transbrake VB's have the center pressure tap blocked off, only way to check line pressure is at the front tap with the trans in high gear.
[Re: cagebob1]
#2575500
11/07/18 07:51 PM
11/07/18 07:51 PM
Posts: 1,602 westerly, ri. usa
440lebaron
westerly, ri. usa
reverse servo with brake on should be 180lbs
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: cagebob1]
#2586730
12/03/18 07:37 PM
12/03/18 07:37 PM
Posts: 304 Mesa, AZ
cagebob1
Mesa, AZ
"reverse servo with brake on should be 180lbs" Are we still talking about a 727 ? I've seen those numbers tossed about for a glide. Any and all input is welcome
