2000 46re - 2002 46re differences #2567508
10/21/18 10:44 PM
10/21/18 10:44 PM
Atlanta, GA
mgoblue9798 Offline OP
Atlanta, GA
I have a low mileage 2000 46re that I would like to swap out in place of a 2002 46re. What changes/parts would I have to swap between the two to make it work properly?
Re: 2000 46re - 2002 46re differences [Re: mgoblue9798] #2567904
10/22/18 05:12 PM
10/22/18 05:12 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If they are the same externally i.e. same tail, etc. they should interchange with the caveat that the ECU might need flashing.
Re: 2000 46re - 2002 46re differences [Re: John_Kunkel] #2567907
10/22/18 05:19 PM
10/22/18 05:19 PM
Atlanta, GA
Atlanta, GA
Read something about swapping out the two valve body sensors, and maybe a neutral safety switch. Would this eliminate the need for a reflash if these were done?
Re: 2000 46re - 2002 46re differences [Re: mgoblue9798] #2567931
10/22/18 06:18 PM
10/22/18 06:18 PM
A727Tflite Offline
A727Tflite  Offline
Pull the pan on the 2000 - if it has the black pressure transducer (it should unless a very early 2000) you are good to go, flashing not required.
If a metal can transducer then you need to install the black plastic sensor and harness assembly from the later style.
Re: 2000 46re - 2002 46re differences [Re: A727Tflite] #2568039
10/22/18 10:05 PM
10/22/18 10:05 PM
Atlanta, GA
Atlanta, GA
Thank you very much to John Kuknel and Transman. I really appreciate you taking the time to reply. If you ever need any paint and body advice I am your guy.
Re: 2000 46re - 2002 46re differences [Re: mgoblue9798] #2568716
10/24/18 03:06 AM
10/24/18 03:06 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Grey area from long ago..... but if you’re changing from the metal can transducer to the later black style, don’t you have to change the aluminum block they go into also as the sensors are retained differently?
Re: 2000 46re - 2002 46re differences [Re: mgoblue9798] #2568885
10/24/18 02:14 PM
10/24/18 02:14 PM
A727Tflite Offline
A727Tflite  Offline
Been a while but if memory serves me the solenoids are retained by a small metal clip inside the block and the transducers are held by the metal plate outside the block and work on all styles.
