What product to apply to machine surfaces for storage? #2567382
10/21/18 04:53 PM
10/21/18 04:53 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
What product/procedure do you recommend to apply to machine surfaces (e.g. blocks, heads) for indoor or garage storage (in the mid-west)?
Anyone ever use a product called Castle Muscle Grease?
Re: What product to apply to machine surfaces for storage? [Re: vinnyd76] #2567385
10/21/18 05:04 PM
10/21/18 05:04 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I usually use plain grease, or oil.
Put in plastic bags.
Cleans right up when needed with a small bit of solvent.
I have mechanical Aptitude.
I can screw up anything.
Re: What product to apply to machine surfaces for storage? [Re: vinnyd76] #2567428
10/21/18 07:06 PM
10/21/18 07:06 PM
pour some 30wt eng oil in a squirt bottle then add solvent till it is the "right" viscosity (as thick as you can get it & it will still spray) & drown everything with more than what you think is enough.
Re: What product to apply to machine surfaces for storage? [Re: vinnyd76] #2567454
10/21/18 08:16 PM
10/21/18 08:16 PM
Maryland
MoparMike1974 Offline
Maryland
Oil is not the best because it can become acidic and it eventually runs off. Grease stays put but it will absorb moisture over time.
The best thing to use is cosmoline. The military has been using it forever. I have opened parts wrapped in cosmoline from the 40's and they still look new.
https://www.cosmolinedirect.com/cosmolin...ASAAEgJUl_D_BwE
Re: What product to apply to machine surfaces for storage? [Re: vinnyd76] #2567473
10/21/18 09:08 PM
10/21/18 09:08 PM
AndyF Offline
AndyF  Offline
Depends how long the stuff will be stored. I used to put oil or grease or Cosmoline blocks and cranks but I eventually figured out that when I store something it sometimes sits for years and years. So these days I just paint the parts after getting them hot tanked. Shoot them with some rattle can paint on all of the machined surfaces and then 10 years from now when you decide to use the block or crank you just get it hot tanked again.
Re: What product to apply to machine surfaces for storage? [Re: vinnyd76] #2567503
10/21/18 10:34 PM
10/21/18 10:34 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
LPS 3 is the best commercially available product I've used. It is essentially cosmoline or something close to it. Never had any rust under it and we get a bunch of opportunities in the spring.
https://www.amazon.com/LPS-Premier-Rust-...+rust+inhibitor
Re: What product to apply to machine surfaces for storage? [Re: vinnyd76] #2567509
10/21/18 10:48 PM
10/21/18 10:48 PM
Niagara, Ontario Canada
mrpatel Offline
mrpatel  Offline
Try googling VCI or VCPI film, we use it to protect 4340 steel parts are work. No oiling, just bag it up and call it good. Andrew
Re: What product to apply to machine surfaces for storage? [Re: vinnyd76] #2567786
10/22/18 12:31 PM
10/22/18 12:31 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I spray on some fluid film or krown lubricant. Been working fine on stuff stored in my (damp) garage.
Re: What product to apply to machine surfaces for storage? [Re: vinnyd76] #2568173
10/23/18 01:57 AM
10/23/18 01:57 AM
5thAve Offline
5thAve  Offline
I usually rub bare stuff down with transmission fluid. Vaseline works good too.
Re: What product to apply to machine surfaces for storage? [Re: vinnyd76] #2568178
10/23/18 02:07 AM
10/23/18 02:07 AM
Omaha Nebraska
Brian_wo Offline
Brian_wo  Offline
Omaha Nebraska
I’ve got white lithium grease in a spray can and was thinking of using it.
who is that guy?
Re: What product to apply to machine surfaces for storage? [Re: vinnyd76] #2568221
10/23/18 09:20 AM
10/23/18 09:20 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I've had no problems with WD-40, i prefer the spray as it to get places I cannot get to with a rag
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: What product to apply to machine surfaces for storage? [Re: gzig5] #2568226
10/23/18 09:50 AM
10/23/18 09:50 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I have been advised to use this product on airplane airframes to protect against corrosion.
WD40...oh my some folks get up in arms over the use of WD40. I have used a lot of it over the years like many others for corrosion protection and lube. I have had several airplane mechanics recommend against it use for corrosion and lube around airplanes.
I/we have used it on my bare chrome moly dragster chassis to keep them from rusting as I do not paint them since I have done weld repairs quite often.
I have 2 dragsters in my shop now, both bare chassis that have been scuffed with scothbrite pads and WD40 a few hundred times that are not rusting much at all after sitting now for more than 10 years. So I have nothing bad to say about WD40.
Re: What product to apply to machine surfaces for storage? [Re: vinnyd76] #2568317
10/23/18 01:09 PM
10/23/18 01:09 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
WD40 will work, but you have to keep up with it. I've found that a single application won't work for long term storage. Something is evaporating. If you apply occasionally it works as well as anything else, but that kinda misses the point. I'll use it on my milling machine table and other surfaces that need protection but would be cumbersome with a thick coating of LPS 3.
Re: What product to apply to machine surfaces for storage? [Re: vinnyd76] #2568351
10/23/18 02:02 PM
10/23/18 02:02 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
White lithium in a spray can will dry out harden and need to be scraped off if left there for a long Peoria of time. When it dries out is may not keep,the rust off.
I like oil and a brush to get in the hard to reach areas. Then a plastic bag to keep the dirt of and mess contained.
Re: What product to apply to machine surfaces for storage? [Re: vinnyd76] #2570549
10/28/18 12:13 PM
10/28/18 12:13 PM
mrpatel Offline
mrpatel  Offline
The VCI film really works well. But we also use another product called Tectyl 900, it is an oil that you can spray from a squirt bottle.
