What product to apply to machine surfaces for storage?
#2567382
10/21/18 04:53 PM
10/21/18 04:53 PM
Posts: 1,562 Macomb, MI
vinnyd76
Macomb, MI
What product/procedure do you recommend to apply to machine surfaces (e.g. blocks, heads) for indoor or garage storage (in the mid-west)?
Anyone ever use a product called Castle Muscle Grease?
Re: What product to apply to machine surfaces for storage?
[Re: vinnyd76]
#2567385
10/21/18 05:04 PM
10/21/18 05:04 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I usually use plain grease, or oil. Put in plastic bags. Cleans right up when needed with a small bit of solvent.
I have mechanical Aptitude. I can screw up anything.
[Re: vinnyd76]
#2567428
10/21/18 07:06 PM
10/21/18 07:06 PM
RapidRobert
pour some 30wt eng oil in a squirt bottle then add solvent till it is the "right" viscosity (as thick as you can get it & it will still spray) & drown everything with more than what you think is enough.
[Re: vinnyd76]
#2567454
10/21/18 08:16 PM
10/21/18 08:16 PM
Posts: 294 Maryland
MoparMike1974
Maryland
Oil is not the best because it can become acidic and it eventually runs off. Grease stays put but it will absorb moisture over time. The best thing to use is cosmoline. The military has been using it forever. I have opened parts wrapped in cosmoline from the 40's and they still look new. https://www.cosmolinedirect.com/cosmolin...ASAAEgJUl_D_BwE
[Re: vinnyd76]
#2568178
10/23/18 02:07 AM
10/23/18 02:07 AM
Posts: 4,437 Omaha Nebraska
Brian_wo
Omaha Nebraska
I’ve got white lithium grease in a spray can and was thinking of using it.
who is that guy?
[Re: gzig5]
#2568226
10/23/18 09:50 AM
10/23/18 09:50 AM
Challenger 1
Cincinnati, Ohio
I have been advised to use this product on airplane airframes to protect against corrosion. WD40...oh my some folks get up in arms over the use of WD40. I have used a lot of it over the years like many others for corrosion protection and lube. I have had several airplane mechanics recommend against it use for corrosion and lube around airplanes. I/we have used it on my bare chrome moly dragster chassis to keep them from rusting as I do not paint them since I have done weld repairs quite often. I have 2 dragsters in my shop now, both bare chassis that have been scuffed with scothbrite pads and WD40 a few hundred times that are not rusting much at all after sitting now for more than 10 years. So I have nothing bad to say about WD40.
