833 ident #2567045
10/20/18 08:31 PM
10/20/18 08:31 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
I picked this up from a friend. Mostly for the parts on the outside of the trans. I want to convert my Cuda to a 4 speed and will probably sell this trans.
Here is the driver side. The only numbers are C-9664 J and above that is 8x7. Next to where it bolts to the bell is a cast set of numbers that say 9x25.
There is no pad for the VIN. The passenger side has C89538 cast into it.
The tailshaft has C958394U cast into it.
It is a Hurst shifter.
Any ideas?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: 833 ident [Re: cdstl] #2567052
10/20/18 08:35 PM
10/20/18 08:35 PM
Pittsburgh,PA
RTSrunner Online content
RTSrunner  Online Content
Pittsburgh,PA
The tail housing is later being a dual-mount.The case looks early since there is no raised pad on the right side above the casting number.h
Re: 833 ident [Re: cdstl] #2567353
10/21/18 04:02 PM
10/21/18 04:02 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Any other opinions?
Thx
Re: 833 ident [Re: cdstl] #2567397
10/21/18 05:43 PM
10/21/18 05:43 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Not much more to say; as stated, a hybrid with a pre-'68 main case and '70-'74 tail with an E-body shifter.
https://www.slantsix.org/articles/4-speeds/ODA833fourspeed1.htm
