833 ident
#2567045
10/20/18 08:31 PM
10/20/18 08:31 PM
Posts: 1,487 STL
cdstl
STL
I picked this up from a friend. Mostly for the parts on the outside of the trans. I want to convert my Cuda to a 4 speed and will probably sell this trans.
Here is the driver side. The only numbers are C-9664 J and above that is 8x7. Next to where it bolts to the bell is a cast set of numbers that say 9x25.
There is no pad for the VIN. The passenger side has C89538 cast into it.
The tailshaft has C958394U cast into it.
It is a Hurst shifter.
Any ideas?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
