I have lost a tenth and a half. #2566158
10/18/18 09:47 PM
10/18/18 09:47 PM
Indianapolis Indiana
Jamie340 Online content OP
Jamie340  Online Content OP
For some reason I have lost a tenth and a half. However the car runs down the track, no miss, just slow. Have you ever seen this with ignition, or with oil?
Re: I have lost a tenth and a half. [Re: Jamie340] #2566176
10/18/18 10:16 PM
10/18/18 10:16 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
What are the incrementals compared to how it ran .... “ before” where is it slower?
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: I have lost a tenth and a half. [Re: Jamie340] #2566229
10/18/18 11:59 PM
10/18/18 11:59 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Ot could be tires or compression. Mine slowed down a tenth after 8 years with over 1,000 quarter mile hits. No miss , seemed to run fine but slower. Low on compression from worn out rings. Re ringed came right back. Do a compression check.
Re: I have lost a tenth and a half. [Re: Jamie340] #2566327
10/19/18 04:14 AM
10/19/18 04:14 AM
Cab_Burge Online work
Cab_Burge  Online Work
As already ask, where did it slow down the most?
Is it and ET and MPH or just ET?
Re: I have lost a tenth and a half. [Re: Jamie340] #2566336
10/19/18 07:49 AM
10/19/18 07:49 AM
According to the Racepack, everything is fine, and incrementals are comparable through the run. The horsepower from the dyno does not translate to track. More ET, than mph.
Re: I have lost a tenth and a half. [Re: Jamie340] #2566340
10/19/18 08:49 AM
10/19/18 08:49 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
So, what are you comparing the loss to? Dyno numbers or actual et loss? If the car is losing .15 seconds, it should show up in your 60, 330, 660 to give you an idea of traction, engine power loss, top end charge. If you are just looking at dyno numbers and predicted et compared to actual et, sometimes dyno numbers aren't always accurate, or the car needs some work.
[image][/image]
Re: I have lost a tenth and a half. [Re: Jamie340] #2566346
10/19/18 09:26 AM
10/19/18 09:26 AM
It is a historical comparison. The engine is the same, actually everything is the same. I freshened the motor, consisted dyno figures, but a loss of
performance through all of the incrementals. The car needs work, I am trying find where. I was hoping that some other racers may have run into this, and could make suggestions. For example, ignition, oils, gasoline. For example, the impulse in the MSD may need replacement, (done that), odd things on that nature.
Re: I have lost a tenth and a half. [Re: Jamie340] #2566347
10/19/18 09:28 AM
10/19/18 09:28 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Years ago I had a 340 that I had beat like a rented mule. It ran its best ET(11.98) then a few weeks later it slowed about .1-.2. I assumed it was tired and it needed to be refreshed, then it broke the crankshaft. Everything else inside the motor looked fantastic, even the bearings. The crank was just broken behind the last rod journal. Next time my car slows that much for no apparent reason it will be inspected more.
68 Barracuda Formula S 340
Re: I have lost a tenth and a half. [Re: Jamie340] #2566362
10/19/18 10:26 AM
10/19/18 10:26 AM
UK
rb446 Offline
rb446  Offline
UK
So you don't think it tyres?....how hard do you beat on them, how old are they, my mate runs a 540 Cuda over here and his 60's/ET went away some, down to 1.34's, tyres looked all ok, plenty of meat on them, put some new tyres on and his 60's came back to 1.23's and it picked back up into the 8.70's.
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: I have lost a tenth and a half. [Re: rb446] #2566363
10/19/18 10:39 AM
10/19/18 10:39 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Over what period of time did it loose this..
a day or weeks or what
wave
Re: I have lost a tenth and a half. [Re: Jamie340] #2566368
10/19/18 10:52 AM
10/19/18 10:52 AM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Converter
5.53 @ 125 1/8th on the launch control..more left in her!
Re: I have lost a tenth and a half. [Re: Eric] #2566402
10/19/18 12:02 PM
10/19/18 12:02 PM
Zumbrota,MN
als499 Offline
als499  Offline
Zumbrota,MN
I rolled a sprag in my converter and lost a second a few years ago. It will show up in the 60 ft.
Re: I have lost a tenth and a half. [Re: Jamie340] #2566405
10/19/18 12:08 PM
10/19/18 12:08 PM
Washington
madscientist Offline
Washington
If the MPH is down, something is eating the power. Like mentioned above, sounds like a converter.
Re: I have lost a tenth and a half. [Re: Jamie340] #2566457
10/19/18 01:44 PM
10/19/18 01:44 PM
This has been going on for about 2-3 years. I had a great performance level, but lost my way and I have not been able to isolate it. The dyno hp number are consistent, if not a little more, but do not reflect on the track. According to the graphing in the Racepack the torque converter is functioning correctly, as with fuel pressure, voltage, drive shaft speed, O2 would suggest a little fat. I even had the front end aligned.
Re: I have lost a tenth and a half. [Re: Jamie340] #2566463
10/19/18 01:53 PM
10/19/18 01:53 PM
I feel like I have done something not knowing that I have done something to upset the balance and performance. The combination is this, 1971 Dodge Demon340 D/SA. Weight 3215 with driver, Sunoco 110, Amsoil 5-20 race,MSD7Al Gold box, 1971
Carter Thermoquad, ATI 5600 converter, 4.86 gear, Hoosier 9" radial. Performance 10:79 @ 121.00 mph, needs to be 10:55.
Re: I have lost a tenth and a half. [Re: Jamie340] #2566495
10/19/18 02:50 PM
10/19/18 02:50 PM
Fat motors are lazy, can you post a picture of #7 spark plug? Please do that up
Re: I have lost a tenth and a half. [Re: Jamie340] #2566511
10/19/18 03:21 PM
10/19/18 03:21 PM
WA
JD Dart Offline
JD Dart  Offline
WA
Send me your racepak data history when it ran good and current. I'll take a look at it, hopefully I can find something
jkcomp5957@yahoo.com
best so far 8.53 @ 158.59 MPH 60'1.240
Re: I have lost a tenth and a half. [Re: Jamie340] #2566530
10/19/18 03:56 PM
10/19/18 03:56 PM
Locomotion Offline
Locomotion  Offline
Just a few ideas I thought I'd throw out:
* I recently found the coil wire/rotor contact inside my distributor cap badly chipped and possibly causing arcing/spark scatter inside the cap. Rotor top had burn marks. But I haven't run it yet to confirm.
* Reluctor gap change?
* Old plug wires?
* Choke pull-off/hose leaking?
* From what I've read about the sensitive Thermoquads, expect the unexpected. (Still learning.) Do you have a good, spare carb to try?
* Any unusual wear indicators on oil pan magnet or in trans pan?
I guess if it's been gradual over a few years, it's not any weather anomalies.
Re: I have lost a tenth and a half. [Re: JD Dart] #2566531
10/19/18 03:56 PM
10/19/18 03:56 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Between breaking down your timeslip Increments and RacePak info that’s a lot of good info. Now double check your chassis for changes. Shocks, pinion angle changes, dragging brakes, etc.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: I have lost a tenth and a half. [Re: Jamie340] #2566535
10/19/18 04:00 PM
10/19/18 04:00 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Using the same dyno? Same engine/head person? Same trans guy? MPH down? 60s? Incrementals? All of a sudden or over a period of time? Have you look at things like the rear, brakes, fuel volume, tried different fuels? Has the carb been looked at by someone? I know a guy had a fast E car till he started "tuning" the TQ and the car slowed significantly.
Agree with all the suggestions. Plug wires, ignition boxes, master switches, grounds, are all things that can cause issues without being obviously broken.
