Re: I have lost a tenth and a half.
[Re: Jamie340]
#2566176
10/18/18 10:16 PM
10/18/18 10:16 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
What are the incrementals compared to how it ran .... “ before” where is it slower?
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: Jamie340]
#2566229
10/18/18 11:59 PM
10/18/18 11:59 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Ot could be tires or compression. Mine slowed down a tenth after 8 years with over 1,000 quarter mile hits. No miss , seemed to run fine but slower. Low on compression from worn out rings. Re ringed came right back. Do a compression check.
[Re: Jamie340]
#2566327
10/19/18 04:14 AM
10/19/18 04:14 AM
Posts: 43,157 Bend,OR USA
Cab_Burge
As already ask, where did it slow down the most? Is it and ET and MPH or just ET?
[Re: Jamie340]
#2566340
10/19/18 08:49 AM
10/19/18 08:49 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
So, what are you comparing the loss to? Dyno numbers or actual et loss? If the car is losing .15 seconds, it should show up in your 60, 330, 660 to give you an idea of traction, engine power loss, top end charge. If you are just looking at dyno numbers and predicted et compared to actual et, sometimes dyno numbers aren't always accurate, or the car needs some work.
[image][/image]
[Re: Jamie340]
#2566346
10/19/18 09:26 AM
10/19/18 09:26 AM
Posts: 168 Indianapolis Indiana
Jamie340
It is a historical comparison. The engine is the same, actually everything is the same. I freshened the motor, consisted dyno figures, but a loss of performance through all of the incrementals. The car needs work, I am trying find where. I was hoping that some other racers may have run into this, and could make suggestions. For example, ignition, oils, gasoline. For example, the impulse in the MSD may need replacement, (done that), odd things on that nature.
[Re: Jamie340]
#2566347
10/19/18 09:28 AM
10/19/18 09:28 AM
Posts: 8,022 Tulsa OK
Bad340fish
Tulsa OK
Years ago I had a 340 that I had beat like a rented mule. It ran its best ET(11.98) then a few weeks later it slowed about .1-.2. I assumed it was tired and it needed to be refreshed, then it broke the crankshaft. Everything else inside the motor looked fantastic, even the bearings. The crank was just broken behind the last rod journal. Next time my car slows that much for no apparent reason it will be inspected more.
68 Barracuda Formula S 340
[Re: Jamie340]
#2566362
10/19/18 10:26 AM
10/19/18 10:26 AM
Posts: 570 UK
rb446
UK
So you don't think it tyres?....how hard do you beat on them, how old are they, my mate runs a 540 Cuda over here and his 60's/ET went away some, down to 1.34's, tyres looked all ok, plenty of meat on them, put some new tyres on and his 60's came back to 1.23's and it picked back up into the 8.70's.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: Eric]
#2566402
10/19/18 12:02 PM
10/19/18 12:02 PM
Posts: 750 Zumbrota,MN
als499
Zumbrota,MN
I rolled a sprag in my converter and lost a second a few years ago. It will show up in the 60 ft.
[Re: Jamie340]
#2566405
10/19/18 12:08 PM
10/19/18 12:08 PM
Posts: 4,457 Washington
madscientist
Washington
According to the Racepack, everything is fine, and incrementals are comparable through the run. The horsepower from the dyno does not translate to track. More ET, than mph. If the MPH is down, something is eating the power. Like mentioned above, sounds like a converter.
[Re: Jamie340]
#2566511
10/19/18 03:21 PM
10/19/18 03:21 PM
Posts: 739 WA
JD Dart
WA
Send me your racepak data history when it ran good and current. I'll take a look at it, hopefully I can find something jkcomp5957@yahoo.com
best so far 8.53 @ 158.59 MPH 60'1.240
[Re: JD Dart]
#2566531
10/19/18 03:56 PM
10/19/18 03:56 PM
Posts: 20,170 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Between breaking down your timeslip Increments and RacePak info that’s a lot of good info. Now double check your chassis for changes. Shocks, pinion angle changes, dragging brakes, etc.
[Re: Jamie340]
#2566535
10/19/18 04:00 PM
10/19/18 04:00 PM
Posts: 11,551 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Using the same dyno? Same engine/head person? Same trans guy? MPH down? 60s? Incrementals? All of a sudden or over a period of time? Have you look at things like the rear, brakes, fuel volume, tried different fuels? Has the carb been looked at by someone? I know a guy had a fast E car till he started "tuning" the TQ and the car slowed significantly.
Agree with all the suggestions. Plug wires, ignition boxes, master switches, grounds, are all things that can cause issues without being obviously broken.
