LA water pumps #2566107
10/18/18 07:40 PM
10/18/18 07:40 PM
70duster340 Offline OP
Just curious, but I see that the high volume water pumps have 6 vanes, while the standard flow has 8 vanes. I would think that 8 vanes would flow more than 6 vanes. Can anybody clear this up for me, please?
Re: LA water pumps [Re: 70duster340] #2566110
10/18/18 07:45 PM
10/18/18 07:45 PM
DuPont, Washington
DZJim Offline
DZJim  Offline
DuPont, Washington
Different drive ratios for different applications, 6 vane for the overdriven. Cavitation issues?
Re: LA water pumps [Re: 70duster340] #2566138
10/18/18 08:58 PM
10/18/18 08:58 PM
Mine is the 8 vane unit, but I added a anticavitation plate to the vanes. Should that help?
Re: LA water pumps [Re: 70duster340] #2566185
10/18/18 10:40 PM
10/18/18 10:40 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
anti-cavitation plates?
Re: LA water pumps [Re: 70duster340] #2566210
10/18/18 11:22 PM
10/18/18 11:22 PM
Yeah, just a round metal plate with holes in it. Drill through the holes into the impeller and attach with the included rivets. I see some of the new high flow pumps come with.
Re: LA water pumps [Re: 70duster340] #2566293
10/19/18 02:20 AM
10/19/18 02:20 AM
the 8 vanes would flow more than a 6 vane. A/C would be overdriven 1.33% so less vanes were needed to avoid cav at higher speeds cuz the WP pulley is always speeded up. Just get an 8 blader & weld on a plate, my last one I cut a piece out of an old washing machine panel. Make its OD slightly less than the vane tips so you can weld em there & cut a center hole to weld it there at the shaft. Ideal clearance from plate flat to t cover flat is .040"
Re: LA water pumps [Re: 70duster340] #2566325
10/19/18 04:10 AM
10/19/18 04:10 AM
Thank you, sir. I already purchased a kit that included a plate and 4 rivets. It's an 8 blade impeller.
