Re: LA water pumps
[Re: 70duster340]
#2566293
10/19/18 02:20 AM
10/19/18 02:20 AM
RapidRobert
the 8 vanes would flow more than a 6 vane. A/C would be overdriven 1.33% so less vanes were needed to avoid cav at higher speeds cuz the WP pulley is always speeded up. Just get an 8 blader & weld on a plate, my last one I cut a piece out of an old washing machine panel. Make its OD slightly less than the vane tips so you can weld em there & cut a center hole to weld it there at the shaft. Ideal clearance from plate flat to t cover flat is .040"
