Hose clamps #2565623
10/17/18 10:07 PM
10/17/18 10:07 PM
70duster340 Offline OP
What would you all recommend for a good hose clamp? Don't want the 340 leaking or overheating. I have used the worm type in the past, but they always seem to need tightening again after a few days. I have tried to locate the OEM type, but haven't had much luck with that.
Re: Hose clamps [Re: 70duster340] #2565668
10/17/18 10:49 PM
10/17/18 10:49 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Restoration? OEM, as sold by pretty much every musclecar parts outlet.
Racecar or non-restoration/driver? Worm clamps I've used may need 1 re-tightening after awhile but not after.
Re: Hose clamps [Re: topside] #2565736
10/18/18 12:57 AM
10/18/18 12:57 AM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
if your not going for "looks" ,there is a clamp used on semis,etc called a constant torque clamp,it has a spring in it that keeps it tight
my ladder of success is missing some rungs
Re: Hose clamps [Re: 70duster340] #2565738
10/18/18 12:59 AM
10/18/18 12:59 AM
I'm almost sure the reason the screw type clamps need retightening is due to the rubber being compress more when hot than cold which makes the clamps not tight anymore work twocents
Re: Hose clamps [Re: 70duster340] #2565763
10/18/18 02:19 AM
10/18/18 02:19 AM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
I use T-bolt clamps.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: Hose clamps [Re: 70duster340] #2565805
10/18/18 09:02 AM
10/18/18 09:02 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
heat shrink clamps are tough to beat for constant torque, but they are one time use
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Hose clamps [Re: 70duster340] #2565887
10/18/18 01:05 PM
10/18/18 01:05 PM
Thanks for the replies. Do the T-bolt clamps keep a constant pressure? I am guessing that the leaks come from the expanding and contracting from the heating and cooling of the antifreeze?
Re: Hose clamps [Re: 70duster340] #2565913
10/18/18 01:50 PM
10/18/18 01:50 PM
I've never had a leak with screw type clamps unless the water pump,( I have retighten them after driving them but they hadn't leak :work): thermostat housing or radiator nipples that the hose fit onto where severely corroded work shruggy
If yours are leaking make sure you know why they are leaking scope wrench
good luck, let us know what you find, that will help others on here in the future thumbs
Re: Hose clamps [Re: 70duster340] #2565914
10/18/18 01:51 PM
10/18/18 01:51 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I use the later flat steel spring clamps wherever. Same stuff used everywhere nowadays.Rubber gets cold-stiff or hot-soft, the spring grip keeps a load on it. Sure they are a fight sometimes, depending on where they're at, but they are the way to go.
Re: Hose clamps [Re: 70duster340] #2566059
10/18/18 06:12 PM
10/18/18 06:12 PM
From everything I have read, the spring clamps seem to be the way to go. I just don't know where I can find a kit with an assortment of various sizes, to include the upper and lower radiator hoses.
I had to replace the upper radiator hose clamp on my 2011 Ram (the OEM spring clamp had rusted and was leaking), but I had to tighten it 3 times before the leak stopped. That is a screw type clamp.
Re: Hose clamps [Re: GoodysGotaCuda] #2566081
10/18/18 06:45 PM
10/18/18 06:45 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I use these and love them! No more skinned knuckles!
I keep extra in the top of the toolbox in case I need to drain the radiator.
I use the Gates Powergrip brand thermoplastic clamps.
They also add to a clean look in the engine compartment.
'63 Dodge 330
11.19 @ 121 mph
Re: Hose clamps [Re: GY3] #2566166
10/18/18 09:56 PM
10/18/18 09:56 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I agree, if you can make the packaging and aesthetics work, they are tough to beat. They are perfect for the application I have here, four hose clamps looks terrible here.
2020 RAM 1500
