#2565734 - 10/17/18 10:52 PM draining a 42re pan
rhad Offline
Loc: garnett kansas
i have to remove the pan on my 42re trans,id like to avoid the mess of getting drenched in tranny fluid,so i have this idea of putting a small hose in thru the dipstick tube and using my mouth to start the suction to drain as much as i can before removing the pan,i dont want or need a mkouth full of fluid,but im thinking of givin it a try,once it starts flowing it should drain a fair amount,im aware that liquid dont run uphill but once it gets started thru suction it should work,
what say you guys am i completely crazy in my old age or just a little goofy?
my ladder of success is missing some rungs
#2565751 - 10/17/18 11:43 PM Re: draining a 42re pan [Re: rhad]
1969ronnie Offline
Loc: massachusetts U.S.A.
Yep , crazy. Give the kid next door $10 to take the pan down and take a atf bath . You are older and wiser and you work smarter, not harder. Act dumb when he is drenched and say "OOP's , I Didn't think that would happen " . http://board whistling
#2565798 - 10/18/18 06:25 AM Re: draining a 42re pan [Re: rhad]
BDW Offline
Loc: Florida
Harbor Freight sells a cheap manual suction pump that will keep the tranny fluid out of your mouth.
#2565863 - 10/18/18 10:11 AM Re: draining a 42re pan [Re: rhad]
JAMESDART Offline
Loc: nj
Poke a hole in the pan with an awl. Ad a drain plug when you have the pan off.
#2565991 - 10/18/18 01:53 PM Re: draining a 42re pan [Re: JAMESDART]
John_Kunkel Offline
Loc: Rio Linda, CA
iagree That's the way I do it except I use a sheet metal screw and gasket to close the hole.
I'm supposed to respect my elders, but its getting harder and harder for me to find one now.
#2566030 - 10/18/18 03:09 PM Re: draining a 42re pan [Re: rhad]
NANKET Offline
Loc: northwest USA
Put it in the side not the bottom. If and when it scrapes bottom it doesn't rip off the head of the screw or drain plug.
25,697 Registered Members
196,732 Topics
Thermostats designs that “fail open” experiences?
by 360view
01/19/19 09:01 AM
Anyone from Livingston N. J. ?
by blewbyu
01/19/19 08:31 AM
Are cassettes making a comeback?
by DUFFMAN
01/18/19 10:34 PM
Indoor (home) emergency heating, kerosene, propane, other??
by A12
01/18/19 10:31 PM
