MT 33 x 10.5 x15w ?beless, and on a 14 inch wide rim? #2565346
10/17/18 01:49 PM
10/17/18 01:49 PM
gregsdart Offline OP
Two questions, can I run them tubeless, and can I run them on a 14 inch wide rim? They save 16 lbs over what I run now.
Re: MT 33 x 10.5 x15w ?beless, and on a 14 inch wide rim? [Re: gregsdart] #2565349
10/17/18 01:51 PM
10/17/18 01:51 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Yes and yes
Re: MT 33 x 10.5 x15w ?beless, and on a 14 inch wide rim? [Re: gregsdart] #2565356
10/17/18 02:14 PM
10/17/18 02:14 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
And yes...Likely a bit more rollout than what you have currently
Re: MT 33 x 10.5 x15w ?beless, and on a 14 inch wide rim? [Re: gregsdart] #2565363
10/17/18 02:24 PM
10/17/18 02:24 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've been amazed how much better my 10.5wx31 M/T were with tubes. Consistency is night and day better.
Doug
Re: MT 33 x 10.5 x15w ?beless, and on a 14 inch wide rim? [Re: gregsdart] #2565368
10/17/18 02:28 PM
10/17/18 02:28 PM
Thanks Al and FM, I have the same rollout as these are , but will be on the wide rim so I assume I will lose a bit going up two inch over measured rim width?
If they will hook as well as the 2078 Goodyears, (33x15x15 Stiff) it ought to pick up a few hundredths in ET. 16 lbs lighter, plus less drag, plus more air pressure, I assume? I have never tried anything on this car except a 14.5x15 radial drag slick, which almost crashed my car.
Re: MT 33 x 10.5 x15w ?beless, and on a 14 inch wide rim? [Re: gregsdart] #2565451
10/17/18 04:54 PM
10/17/18 04:54 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW we run a 29.5x10.5 on a 12" rim on the Vette. Our dragster has a 33.5x13.5 on a 16" wide rim, and my Stratus will be sporting a 33.5x10.5W on a 16" wide rim if we can get the tranny figured out at SCSN.
Re: MT 33 x 10.5 x15w ?beless, and on a 14 inch wide rim? [Re: Al_Alguire] #2565614
10/17/18 09:57 PM
10/17/18 09:57 PM
Suffolk,VA
dragracedr Online content
dragracedr  Online Content
Suffolk,VA
Not to seal the thread, Al, but do you run the 29.5x10.5 on beadlock rim, screwed, or just glued ?
Re: MT 33 x 10.5 x15w ?beless, and on a 14 inch wide rim? [Re: gregsdart] #2565624
10/17/18 10:09 PM
10/17/18 10:09 PM
Al, do you run tubes?
Re: MT 33 x 10.5 x15w ?beless, and on a 14 inch wide rim? [Re: gregsdart] #2565626
10/17/18 10:09 PM
10/17/18 10:09 PM
Re: MT 33 x 10.5 x15w ?beless, and on a 14 inch wide rim? [Re: gregsdart] #2565657
10/17/18 10:36 PM
10/17/18 10:36 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
I run a 28x10.5 on a 12 inch wheel glued with 15 PSI no tubes
Re: MT 33 x 10.5 x15w ?beless, and on a 14 inch wide rim? [Re: gregsdart] #2565670
10/17/18 10:50 PM
10/17/18 10:50 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I don't run tubes, in fact we don't run them in any of the cars. All three have double bead locks though. We have run with tubes on the 29.5x10.5 stuff in the Vette and we were actually slower. FWIW I think any option will work on a 29.5x10.5 deal. Glue works well for most. I would not use screws, and beadlocks just make life easier.
FWIW the dragster and my Stratus both 60' 1.0X and the Vette is usually 1.13-1.15
Re: MT 33 x 10.5 x15w ?beless, and on a 14 inch wide rim? [Re: gregsdart] #2565704
10/17/18 11:47 PM
10/17/18 11:47 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mine are glued.
Doug
Re: MT 33 x 10.5 x15w ?beless, and on a 14 inch wide rim? [Re: gregsdart] #2565889
10/18/18 01:07 PM
10/18/18 01:07 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
33 x 10.5W-15 are huge.
Why such a big tire, couldn't you get away with a 31 x105W?
Re: MT 33 x 10.5 x15w ?beless, and on a 14 inch wide rim? [Re: Sammy] #2566566
10/19/18 04:56 PM
10/19/18 04:56 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
You can run them tubeless but I wouldn't. They really are made for use with tubes. 16" wide beadlocks are best for high HP applications. We've made literally hundreds of runs on the 16" wheel version and well into the 3's 1/8th mile. They actually are a great tire once you get them figured out.
Re: MT 33 x 10.5 x15w ?beless, and on a 14 inch wide rim? [Re: Sammy] #2570501
10/28/18 08:29 AM
10/28/18 08:29 AM
Too much rear gear already with a 4.56 driving a 103 rollout Goodyear.
Re: MT 33 x 10.5 x15w ?beless, and on a 14 inch wide rim? [Re: gregsdart] #2570530
10/28/18 11:27 AM
10/28/18 11:27 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
4.10 with a 10.5wx31 would haul.
Doug
Re: MT 33 x 10.5 x15w ?beless, and on a 14 inch wide rim? [Re: dvw] #2570597
10/28/18 02:40 PM
10/28/18 02:40 PM
Doug
That would bring my rpm in the traps down a couple hundred to about 7200 from 7400 i would guess ? Doug, why do you think a 4.10 rather than my current 4.56, and shorter tire would be faster, and where would the gains be, 60 ft or down track, or both?
Re: MT 33 x 10.5 x15w ?beless, and on a 14 inch wide rim? [Re: gregsdart] #2570601
10/28/18 02:55 PM
10/28/18 02:55 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The 10.5Wx31 should hook at your power and weight. Any bigger will just slow it down. Depends on converter slip for your trap RPM. Mines about 7300@150 with a 4.30 10.5wx31. I'd love to run a wider rim as mine are only 10". Not enough room. Been numerous 1.25 60ft this year (foot brake 3345lbs). Last 2 passes were 1.25, 85 passes on the tires. I'll bet there's even more left if we tighten up the shocks.
Doug
