440 source strokers? #2564080
10/14/18 09:49 PM
10/14/18 09:49 PM
illinois
bigblk66_coronet Offline OP
illinois
Anyone have any experience with 440 Source Strokers? Thinking about getting one but want to make sure they are good quality, Thanks Joe
66 Dodge Coronet 500 440w/727 11:10 30 over 440 w/292 purple shaft,stock Eddy heads,3:23,full exhaust Best ET. 12.38 @110 in street trim
Re: 440 source strokers? [Re: bigblk66_coronet] #2564090
10/14/18 09:57 PM
10/14/18 09:57 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: 440 source strokers? [Re: bigblk66_coronet] #2564147
10/14/18 11:11 PM
10/14/18 11:11 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
That's an interesting read, I'm conceitering a new short block with there 4.25 crank. I was looking on there site last night and wòndering about there pistons, I used Icon in a Ford build with success. The question about balancing, every part would be truly balanced before assembly.
Have a great day
Iowan
"obsolete is neat"
Re: 440 source strokers? [Re: bigblk66_coronet] #2564151
10/14/18 11:14 PM
10/14/18 11:14 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
I have belted piss out of my 440 Source 528, it has run 9.2's @ 145 in a 63 Ply, now in my Barracuda and it has even survived a split block, it all went into another block.
No problem .
1963 Plymouth Max Wedge
1971 Barracuda
Re: 440 source strokers? [Re: ozymaxwedge] #2564180
10/15/18 12:00 AM
10/15/18 12:00 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
No problem .
Is your 528 based on a stock 440 block?
Re: 440 source strokers? [Re: RTSrunner] #2564209
10/15/18 01:01 AM
10/15/18 01:01 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
No problem .
Same here. My Indy headed 500 cubic inch engine ran 275 passes with many in the 8.60’s@155 mph plus before I found a cracked block during a freshen job. It to is still going in a street car. I will be putting together a 4.250 stroke mega block combo this winter.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 440 source strokers? [Re: RTSrunner] #2564221
10/15/18 01:49 AM
10/15/18 01:49 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
No problem .
Yes, the one I split and the replacement both 440 blocks and both 1/2 grout filled .
1971 Barracuda
Re: 440 source strokers? [Re: bigblk66_coronet] #2564239
10/15/18 03:38 AM
10/15/18 03:38 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
My 440/493 is a 440Source 4.15 stroker kit. I use their pistons and rods also. My 63 is a street car that I only race about once a year lately but this eng has been in my car since 2011 and I have raced it about 7 times since then. Shift at 6200 and trap at 6400. Has run 10.70's driven to track and raced as I drive it. Its still going strong and running great. Ron
Re: 440 source strokers? [Re: bigblk66_coronet] #2564350
10/15/18 12:21 PM
10/15/18 12:21 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Might want to check out Tom Molnar's stuff also. I run his crank and rods and JE pistons. He likes CP pistons as do I but I was on a time crunch so I went with JE.
http://www.molnartechnologies.com/
5.53 @ 125 1/8th on the launch control..more left in her!
Re: 440 source strokers? [Re: Eric] #2564353
10/15/18 12:25 PM
10/15/18 12:25 PM
up iagree scope twocents
Re: 440 source strokers? [Re: bee1971] #2564563
10/15/18 08:19 PM
10/15/18 08:19 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Great product, great price...We have built lots of them. And we race the hell out of them.
I always opt for the ARP upgrade, and we always use the plate on the bottom that re-enforces everything..Balance on the kits has been good, and the bearings match...
Re: 440 source strokers? [Re: Eric] #2564617
10/15/18 10:21 PM
10/15/18 10:21 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
same here with exception of Icon pistons, real happy with his stuff. up up
Re: 440 source strokers? [Re: dartman366] #2564624
10/15/18 10:33 PM
10/15/18 10:33 PM
Dragula Offline
Dragula  Offline
We like the Icon pistons....If you look at the name on the pistons in the 440Source kits, they say Icon on them.
Re: 440 source strokers? [Re: bigblk66_coronet] #2564655
10/15/18 11:37 PM
10/15/18 11:37 PM
tucson az
frank Offline
frank  Offline
tucson az
I'm working on my second Source engine now B 400/512. First was RB 440/496. Completed engine in 2013 and runs perfect. Engine builder said it was a good kit and needed very little work. Start assembly on second next week after I get a few parts. Both of these kits were purchased in about 2011 I think. I have not used any of their newer kits but I have no complaints of their older kits.
Re: 440 source strokers? [Re: frank] #2565017
10/16/18 07:20 PM
10/16/18 07:20 PM
Dragula Offline
Dragula  Offline
Like I said, we have a tone of them running around here. The guys I race with all have them. The 440/512 is a power house and the most popular, and we recently built a 440/526 and a 400/512 with the light weight crank option. If you can keep the rpm in check, life is good. I personally have nearly 1000 documented passes on my old 440/512 combo.
I would love to build one of these with a good after market block someday.
Re: 440 source strokers? [Re: Dragula] #2565042
10/16/18 08:12 PM
10/16/18 08:12 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Not trying to start a catfight ; simply looking for what people should expect these days.
Originally there were regular complaints about excessive taper and out-of-round journals w/ 440 Source cranks. This was not limited to that brand, since a number of the offshore cranks had (and may still have) similar problems.
I believe the quality of at least one other brand that also had this reputation has improved, based on what I've measured myself. Has 440 Source likewise improved their production QC? What are the machinists & engine builders who work with these parts saying about how close they are to being "ready to run" these days? It used to be almost SOP that people were told to budget for getting the rods & mains turned. It would be nice if that was no longer the case.
At one point their kits came with Ross pistons, then they switched to Icon. I'm not a big fan of Icons (not a big fan of BBM Ross pistons these days, either), but they have a lot of different versions that fit all those stroker kit options.
Re: 440 source strokers? [Re: BradH] #2565082
10/16/18 09:21 PM
10/16/18 09:21 PM
the 440 (528 cube) piston CH is either 1.355" or 1.320". Would there be a long term longevity issue with that short of CH? Any other (potential) issues just from that dimention?
Re: 440 source strokers? [Re: Dragula] #2565172
10/17/18 12:59 AM
10/17/18 12:59 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
I did a 400/512 with the lightweight crank, as well. Have you had it out and about yet? What do you think?
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: 440 source strokers? [Re: OhioMopar] #2565234
10/17/18 07:53 AM
10/17/18 07:53 AM
Dragula Offline
Dragula  Offline
We ran the 400/512 with light weight crank all summer. We had some issues early on, but seemed to get by them. Quickest it went on pump gas was a 6.19 in the 1/8th at 110....The 440/512 went as quick as 6.14 at nearly 112....We were catching the 440 based one as we kept jetting the 400 up but ran out of season. The 60ft with it has been 1.35, its the top end we have been looking for more. It doesn't pull as hard on the top end as the other engine. Same cam and heads, so we have been wondering why...
Re: 440 source strokers? [Re: Dragula] #2565245
10/17/18 09:12 AM
10/17/18 09:12 AM
BradH Offline
BradH  Offline
Differences in the intake and/or carb?
