marine battery in a mopar #256447
03/16/09 11:15 PM
03/16/09 11:15 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
Any reason I can not use one in my old cuda? There was one in the trunk of an old car I just bought and it looks new and tests out good.
Re: marine battery in a mopar [Re: HotRodDave] #256448
03/17/09 12:04 AM
03/17/09 12:04 AM
I depends on whether it's a "real" marine / deep cycle battery, or just a car battery.
A true deep cycle battery is designed for just what it says--deep cycle, as in, low, long discharge, like running a golf cart, or used in banks for UPS backups or wind/ solar power.
An automotive battery is designed for LOTS of cranking amps for short periods, instead. If you can't tell, take it to a "real" battery place, and by that I don't mean Sears or the nearest xxxx-mart.
Re: marine battery in a mopar [Re: HotRodDave] #256449
03/17/09 01:19 AM
03/17/09 01:19 AM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Nope, they work great...
Re: marine battery in a mopar [Re: Lefty] #256450
03/17/09 05:53 AM
03/17/09 05:53 AM
Cleveland,Ohio
CtownChris Offline
CtownChris  Offline
Cleveland,Ohio
They make "real" marine stating batteries also. If it has the CCA you need, just put it in.
If it says "deep cycle" it will start your car but.... not built as a starting battery. It won't last starting a motor for long.
"Always go forward: Never go straight"
Re: marine battery in a mopar [Re: CtownChris] #256451
03/17/09 03:35 PM
03/17/09 03:35 PM
Kalispell Mt.
Kalispell Mt.
It does say deep cycle on it.
Re: marine battery in a mopar [Re: HotRodDave] #256452
03/17/09 04:42 PM
03/17/09 04:42 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
used one for 2 yrs in my 90 caravan
Re: marine battery in a mopar [Re: HotRodDave] #256453
03/17/09 05:39 PM
03/17/09 05:39 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
I've had my yellow top optima on my Road runner for over 5 years without a problem. For a car I never drive this battery is perfect.
For free I would try it.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: marine battery in a mopar [Re: HotRodDave] #256454
03/17/09 06:17 PM
03/17/09 06:17 PM
Pizza Bucket
snuggles Offline
snuggles  Offline
Pizza Bucket
I ran one for several years, can't remember if it said deep cycle or not.
