marine battery in a mopar
#256447
03/16/09 11:15 PM
03/16/09 11:15 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Any reason I can not use one in my old cuda? There was one in the trunk of an old car I just bought and it looks new and tests out good.
Re: marine battery in a mopar
[Re: HotRodDave]
#256448
03/17/09 12:04 AM
03/17/09 12:04 AM
I depends on whether it's a "real" marine / deep cycle battery, or just a car battery.
A true deep cycle battery is designed for just what it says--deep cycle, as in, low, long discharge, like running a golf cart, or used in banks for UPS backups or wind/ solar power.
An automotive battery is designed for LOTS of cranking amps for short periods, instead. If you can't tell, take it to a "real" battery place, and by that I don't mean Sears or the nearest xxxx-mart.
[Re: Lefty]
#256450
03/17/09 05:53 AM
03/17/09 05:53 AM
Posts: 412 Cleveland,Ohio
CtownChris
Cleveland,Ohio
They make "real" marine stating batteries also. If it has the CCA you need, just put it in.
If it says "deep cycle" it will start your car but.... not built as a starting battery. It won't last starting a motor for long.
"Always go forward: Never go straight"
[Re: CtownChris]
#256451
03/17/09 03:35 PM
03/17/09 03:35 PM
HotRodDave
Kalispell Mt.
It does say deep cycle on it.
[Re: HotRodDave]
#256453
03/17/09 05:39 PM
03/17/09 05:39 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
I've had my yellow top optima on my Road runner for over 5 years without a problem. For a car I never drive this battery is perfect.
For free I would try it.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
