Pulled the Dana cover to inspect the carnage #2564278
10/15/18 08:56 AM
10/15/18 08:56 AM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
A hell of a lot of racket for one piece. Cheapy street gear. About 125 passes.
Doug
Re: Pulled the Dana cover to inspect the carnage [Re: dvw] #2564313
10/15/18 11:24 AM
10/15/18 11:24 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Not that they are cheap. Street gears are more brittle than race gears. Just like chrome sockets and impact sockets.
[image][/image]
Re: Pulled the Dana cover to inspect the carnage [Re: dvw] #2564318
10/15/18 11:30 AM
10/15/18 11:30 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Dont take much to make a mess of things - at least you found it before it decided to destroy everthing and hurt the transmission!
Re: Pulled the Dana cover to inspect the carnage [Re: dvw] #2564346
10/15/18 12:13 PM
10/15/18 12:13 PM
Cab_Burge Online work
Cab_Burge  Online Work
Seeing the lines inside on that tooth tells me it was defective since it was made whiney shruggy
What ratio?
Re: Pulled the Dana cover to inspect the carnage [Re: Cab_Burge] #2564351
10/15/18 12:23 PM
10/15/18 12:23 PM
Kirkland, Washington
Pacnorthcuda Offline
What ratio?
Based on that pic, I'm surprised it didn't fail on the first pass.
Re: Pulled the Dana cover to inspect the carnage [Re: dvw] #2564390
10/15/18 01:50 PM
10/15/18 01:50 PM
Locomotion Offline
Locomotion  Offline
I got lucky once as well. In a final round, I heard "POP" over all the noise of the car launching. I stayed in it and won the race. Sure enough, that one "pop" was one tooth off of an 8 3/4 gear. I always wondered if that standard 4.86 gear was saved from stripping more teeth because they were REM'ed and cryo'ed. But there was another one that did take out enough teeth to abort the run and hurt the trans.
Re: Pulled the Dana cover to inspect the carnage [Re: dvw] #2564392
10/15/18 01:56 PM
10/15/18 01:56 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
It was a 4.30. Only one I found that fit a 3 series spool. US Gear makes a 4.30 pro-gear using 9310 material instead of 8620. It will require a 5 series spool.
Doug
Re: Pulled the Dana cover to inspect the carnage [Re: dvw] #2564528
10/15/18 06:32 PM
10/15/18 06:32 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
The Duster would get about 600 passes out of our street ring and pinion before it started eating itself. We have a pro gear in the Daytona.
