Re: A few battery cable questions
[Re: MI_Custumz]
#2563806
10/14/18 12:12 PM
10/14/18 12:12 PM
Posts: 19,641 north of coder
moparx
#1 - the cables touching each other won't hurt a thing with the battery out. #2 - if you add a cut off, it has to include the wire to the battery on one side, with all the other wires to the system, on the other. it can be on the negative side, but "most" racing organizations require it to be on the positive side. that way, if something comes in contact with the body structure and a connected part, the circuit will not be re-energized. i'm not a fan of those key type switches. they seem pretty cheap inside with tiny contacts, no matter what continuous amp rating they have. just my opinion. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: MI_Custumz]
#2563944
10/14/18 04:45 PM
10/14/18 04:45 PM
Posts: 2,683 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Don't even think about putting the cut-off on the negative side. It can cause things to happen that you will never figure out.
2011 Drag Pak Challenger
[Re: rickseeman]
#2564066
10/14/18 09:27 PM
10/14/18 09:27 PM
Posts: 5,660 Port Huron, Michigan
MI_Custumz
Don't even think about putting the cut-off on the negative side. It can cause things to happen that you will never figure out. Why is that? I am not arguing, more of wanting to learn. Will it do the same thing as far as not allowing lights to come on/power draw and keep you from starting the vehicle? I am gathering from the replies so far the switch will go where the battery end is now and an extension to the battery. I don't need it to kill the car like if it was at the track, just keep battery drain from happening and keep it from starting. This was the instructions on a switch at Autozone. This is why I'm asking.
[Re: Blusmbl]
#2564070
10/14/18 09:30 PM
10/14/18 09:30 PM
MI_Custumz
I have a similar one on the battery now. It's on the negative per the install instructions, but wanted a heavier duty one.
[Re: MI_Custumz]
#2564093
10/14/18 10:01 PM
10/14/18 10:01 PM
RapidRobert
Don't even think about putting the cut-off on the negative side. It can cause things to happen that you will never figure out. Why is that? I am not arguing, more of wanting to learn. [/quote] Me too bro.
