Originally Posted By Blusmbl
#1, as long as the battery is out of the system, that is fine.
#2, this is probably the cheapest and easiest option. Your version B won't actually disconnect the electrical system since the ground is still connected to the body.
https://www.amazon.com/Side-Battery-Master-Disconnect-Switch/dp/B001N72FES
I have a similar one on the battery now. It's on the negative per the install instructions, but wanted a heavier duty one.
