Strange question- REAR WHEEL TORQUE for 440
#2563995
10/14/18 06:44 PM
10/14/18 06:44 PM
Posts: 16,477 Canada
CrAzYMoPaRGuY
Canada
We are trying an EFI setup for a 440 and one of the main parameters we have to enter is "rear wheel torque value".
440 - .030 with six pack pistons. 3906 heads that were cut .020 or .030 with steel gaskets. MP .455 lift 272 duration hydraulic cam
Has headers, mandrel 2 1/2 out rear, Street Dominator intake
What's a decent guess at rear wheel torque???
THANKS!!!
CrAzYMoPaRGuY
Re: Strange question- REAR WHEEL TORQUE for 440
[Re: CrAzYMoPaRGuY]
#2563996
10/14/18 06:44 PM
10/14/18 06:44 PM
CrAzYMoPaRGuY
Canada
I'm guessing 400 ft lbs??
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#2564047
10/14/18 08:40 PM
10/14/18 08:40 PM
CrAzYMoPaRGuY
Canada
It's got 3.91 gears and a 518 4 speed trans. Asks for a rear wheel torque and says it defaults to mild Chevy 350 specs which it says is is 300 ft lb....
CrAzYMoPaRGuY
[Re: dOc !]
#2564115
10/14/18 10:29 PM
10/14/18 10:29 PM
CrAzYMoPaRGuY
Canada
A strange Q from a very strange dude in miniVancouver ? ... PERISH that tHoUgHt !!
oleHam rElEaSe him nOw ... Or is it visa vErSa ??!! I'm hungry Doc. Let's go for lunch....? Hours and hours, and not one guess. lol We are using 400. Will see how it works You pay for lunch btw. Mr DeEEEp poCKETs
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#2564248
10/15/18 04:12 AM
10/15/18 04:12 AM
Posts: 4,848 Memphis
HemiRick
Memphis
Rear wheel torque would be flywheel torque times 1st gear ratio times rear gear ratio and would be a figure in the thousands. This is with a manual trans w an auto the torque converter would increase it even more....
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: CrAzYMoPaRGuY]
#2564339
10/15/18 12:04 PM
10/15/18 12:04 PM
Posts: 43,126 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#2564552
10/15/18 07:53 PM
10/15/18 07:53 PM
CrAzYMoPaRGuY
Canada
Thanks Cab!! We are doing what you said!! No concrete figure and we HAVE to enter a number, drives us crazy....
CrAzYMoPaRGuY
[Re: HemiRick]
#2564557
10/15/18 08:06 PM
10/15/18 08:06 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
Rear wheel torque would be flywheel torque times 1st gear ratio times rear gear ratio and would be a figure in the thousands. Only if the program is expecting MAXIMUM torque at the wheels, and not the ratio in a direct (1:1) high gear. OP didn't specify. And don't forget to divide by 2 since half goes to each wheel.
