Re: stripped holley threads
[Re: 68DART360]
#2564000
10/14/18 06:51 PM
10/14/18 06:51 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
BLP website has a thread and pitch chart for Holley carbs then you can order the repair kit from there. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: 68DART360]
#2564010
10/14/18 07:22 PM
10/14/18 07:22 PM
Posts: 25,748 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Just gotta love the orphan #12-24 threads in the main body.
[Re: 68DART360]
#2564043
10/14/18 08:36 PM
10/14/18 08:36 PM
Posts: 11,530 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
12-24 Heli-coil kit at NAPA BK 7703043. Heli-coil HC5521-1 on the bag. I might have one around here.
[Re: 68DART360]
#2564061
10/14/18 09:06 PM
10/14/18 09:06 PM
Posts: 12,025 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have drilled and tapped carb bodies so I could use 1/4" bolts. Using 1/4" bolts also allowed me to find ones that were slightly longer so that there are more threads engaged. It seems like the holes only had to be 1/64" or 1/32" bigger.
Master, again and still
