Hanging the front of the Trans? #2563627
10/13/18 11:25 PM
10/13/18 11:25 PM
Tucson, Arizona
clonestocker Offline OP
Tucson, Arizona
Anybody have a simple way to hang the front of the trans with the motor out. Will have the cross member at the rear. Pics? thx matt
[img] [/img]
Re: Hanging the front of the Trans? [Re: clonestocker] #2563629
10/13/18 11:35 PM
10/13/18 11:35 PM
indiana
65mike Offline
65mike  Offline
indiana
I do not have picture but I always used a bumper jack upright across the frame rails and a couple long bolts in bell housing bolt holes. hope this helps
Re: Hanging the front of the Trans? [Re: clonestocker] #2563632
10/13/18 11:41 PM
10/13/18 11:41 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Have a mid plate now,,but a cargo strap with a ratchet handle works fine.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Hanging the front of the Trans? [Re: clonestocker] #2563637
10/13/18 11:49 PM
10/13/18 11:49 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Or a 2x4 on the apron tops with a cargo strap & a bolt through the trans mounting face. Or a jack under the mounting area if the car isn't going to move.
Re: Hanging the front of the Trans? [Re: topside] #2563650
10/14/18 12:13 AM
10/14/18 12:13 AM
Lowes
steve660 Offline
steve660  Offline
Lowes
Ratchet strap hooked over the torsion bars.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
Re: Hanging the front of the Trans? [Re: steve660] #2563662
10/14/18 12:27 AM
10/14/18 12:27 AM
iagree scope
I use a cheap Harbor Freight ratchet strap under the back of the oil pan wrap around the torsion bars on the stick shift motors I work on when the tranny and or bellhousing is out of the car up
I use to stuff a 2x4 in between the bottom of the oil pan and the steering link between the idler arm and pitman arm, no more realcrazy tsk Neither one of those arms are designed to hold weight on them, especially the weight of a BB motor realcrazy
Re: Hanging the front of the Trans? [Re: clonestocker] #2563680
10/14/18 12:54 AM
10/14/18 12:54 AM
Washington
W
weedburner Offline
weedburner  Offline
W
Washington
Not a mopar, but I have made separate midplates that stay in the car. It fits between the block plate and bell, allowing removal of the engine/clutch while leaving the bell/midplate in place to support the trans. You can also remove the trans/clutch/bell and leave the midplate in place to support the back of the engine...
Grant
Re: Hanging the front of the Trans? [Re: weedburner] #2564002
10/14/18 06:55 PM
10/14/18 06:55 PM
Tucson, Arizona
Tucson, Arizona
Thanks for the input guys. I wasn't sure how far the bell housing face was in the engine compartment. 1x6 and a couple of bolts & bam. thx again
[img] [/img]
Re: Hanging the front of the Trans? [Re: clonestocker] #2564008
10/14/18 07:17 PM
10/14/18 07:17 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I always use a piece of pipe across the top of the frame rails.
Re: Hanging the front of the Trans? [Re: clonestocker] #2564127
10/14/18 10:43 PM
10/14/18 10:43 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I have a piece of angle iron notched to fit the torsion bars and use a couple long bolts in the trans.
Re: Hanging the front of the Trans? [Re: clonestocker] #2564223
10/15/18 01:52 AM
10/15/18 01:52 AM
Portland, Oregon
Digger73 Offline
Digger73  Offline
Portland, Oregon
Don't forget to put a C-clamp on the bell housing to hold the converter in place if leaving it in the trans.
Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
Re: Hanging the front of the Trans? [Re: Digger73] #2564321
10/15/18 11:37 AM
10/15/18 11:37 AM
hemi-itis Offline
hemi-itis  Offline
Digger73 (Mike)
A length of flat stock with a hole on the end and bolt to the trans holds it in even if it's getting transported.
