Taller front radial tire?
#2561343
10/09/18 12:10 PM
10/09/18 12:10 PM
Posts: 4,684 Wichita
GY3
Wichita
I'm currently running a 165/80/15 radial on 15x4 wheels on the front of my '63. The front wheel openings on this car are MASSIVE and dwarf this size of tire. Any taller yet slim street radials out there?
Re: Taller front radial tire?
[Re: ZIPPY]
#2561402
10/09/18 01:52 PM
10/09/18 01:52 PM
BradH
M&H sells a 185/75R15, but it's only 26" tall which is not a huge improvement.
I have purchased a set of the M&H to replace the 215/75R15 front tires on my 5" rims. The 215s measure about 27" tall, but I'm going w/ the M&Hs to help lower the front of my Challenger a bit more.
[Re: GY3]
#2561531
10/09/18 06:33 PM
10/09/18 06:33 PM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
I run a 185/80R15 on my Satellite
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#2561551
10/09/18 07:14 PM
10/09/18 07:14 PM
GY3
Wichita
Tex What brand?
[Re: BradH]
#2561606
10/09/18 09:16 PM
10/09/18 09:16 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Brad I really liked the way my car used to drive with the M&H 185/75R15 on the front.
"Just a Bracket car dressed up like a streetcar"
[Re: GY3]
#2561666
10/09/18 11:19 PM
10/09/18 11:19 PM
tex013
Sydney,Australia
Tex What brand? Kumho and Hankook . Korean tyres I am sure TireRack etc should be able to help you out Tex
[Re: tex013]
#2561667
10/09/18 11:23 PM
10/09/18 11:23 PM
BradH
Tex What brand? Kumho and Hankook . Korean tyres I am sure TireRack etc should be able to help you out Tex FWIW, I wasn't able to find that size available in the U.S. It must be a pretty obscure size for an OEM fitment.
[Re: mopar dave]
#2561700
10/10/18 12:13 AM
10/10/18 12:13 AM
GY3
Wichita
Yep. M/T sportsman S/R radial. 26 and 28 tall. Been using the 26" on my Barracuda. Nice tire. That's the only one I've found that fills the bill. Pricy, though, at over $200/tire for 28"! Ouch!
[Re: GY3]
#2561710
10/10/18 12:41 AM
10/10/18 12:41 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Yep. M/T sportsman S/R radial. 26 and 28 tall. Been using the 26" on my Barracuda. Nice tire. That's the only one I've found that fills the bill. Pricy, though, at over $200/tire for 28"! Ouch! Not to mention ugly as heck, with that funky tread pattern. I’ve written M/T about this very subject in the recent past. With all the good radial rear rear tires these days, the market is void of drag-specific radial front runners. I’ve gotten no response from them which is disappointing. But I’ve got to believe they can see the hole in their lineup, and the market potential (??).
[Re: BradH]
#2561770
10/10/18 03:19 AM
10/10/18 03:19 AM
tex013
Sydney,Australia
Tex What brand? Kumho and Hankook . Korean tyres I am sure TireRack etc should be able to help you out Tex FWIW, I wasn't able to find that size available in the U.S. It must be a pretty obscure size for an OEM fitment. shoot , just realised I have Federal brand on front at the moment its a pain with the reduction of tyre sizes available now Tex
[Re: GY3]
#2561784
10/10/18 07:22 AM
10/10/18 07:22 AM
Posts: 46 Finland
LUMI
Finland
[Re: GY3]
#2561833
10/10/18 11:10 AM
10/10/18 11:10 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
The M/T Sportsman SR fronts are the ONLY tall AND skinny radials out there. Everything else is either 26" or shorter. Most are 25", no matter what the online measurements tell you. Anything taller than 26" gets too wide to be considered a "skinny" to me, except for the M/Ts.
[Re: GY3]
#2561973
10/10/18 03:37 PM
10/10/18 03:37 PM
an8sec70cuda
LUMI...You probably believe a 165R15 tire will blow out at speeds above 112 mph too.
