Taller front radial tire? #2561343
10/09/18 12:10 PM
10/09/18 12:10 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
I'm currently running a 165/80/15 radial on 15x4 wheels on the front of my '63. The front wheel openings on this car are MASSIVE and dwarf this size of tire. Any taller yet slim street radials out there?
'63 Dodge 330
11.19 @ 121 mph
Re: Taller front radial tire? [Re: GY3] #2561350
10/09/18 12:18 PM
10/09/18 12:18 PM
moparx Offline
moparx  Offline
maybe a 195-205-75 ? different brands can be different heights and widths by as much as 3/4-1".
beer
Re: Taller front radial tire? [Re: GY3] #2561392
10/09/18 01:38 PM
10/09/18 01:38 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
M&H sells a 185/75R15, but it's only 26" tall which is not a huge improvement.
Re: Taller front radial tire? [Re: ZIPPY] #2561402
10/09/18 01:52 PM
10/09/18 01:52 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I have purchased a set of the M&H to replace the 215/75R15 front tires on my 5" rims. The 215s measure about 27" tall, but I'm going w/ the M&Hs to help lower the front of my Challenger a bit more.
Re: Taller front radial tire? [Re: GY3] #2561531
10/09/18 06:33 PM
10/09/18 06:33 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
I run a 185/80R15 on my Satellite
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Taller front radial tire? [Re: tex013] #2561551
10/09/18 07:14 PM
10/09/18 07:14 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Tex
What brand?
'63 Dodge 330
11.19 @ 121 mph
Re: Taller front radial tire? [Re: GY3] #2561585
10/09/18 08:24 PM
10/09/18 08:24 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Yep. M/T sportsman S/R radial. 26 and 28 tall. Been using the 26" on my Barracuda. Nice tire.
Re: Taller front radial tire? [Re: BradH] #2561606
10/09/18 09:16 PM
10/09/18 09:16 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Brad I really liked the way my car used to drive with the M&H 185/75R15 on the front.
"Just a Bracket car dressed up like a streetcar"
Re: Taller front radial tire? [Re: GY3] #2561641
10/09/18 10:42 PM
10/09/18 10:42 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I've run as tall as 205/75 & 215/75 R 15s on early Bs - just regular street tires, though - and they fill the opening nicely. Might have some interference at the bottom front fender corners depending on ride height & track width. Usually a 45-degree cut with some snips, no more than an inch, cures that; only needed to touch up the edge of the cut.
Re: Taller front radial tire? [Re: GY3] #2561666
10/09/18 11:19 PM
10/09/18 11:19 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Tex
What brand?
Kumho and Hankook . Korean tyres
I am sure TireRack etc should be able to help you out
Tex
New best MPH 130.32
Re: Taller front radial tire? [Re: tex013] #2561667
10/09/18 11:23 PM
10/09/18 11:23 PM
BradH Offline
BradH  Offline
Tex
What brand?
Tex
FWIW, I wasn't able to find that size available in the U.S. It must be a pretty obscure size for an OEM fitment.
Re: Taller front radial tire? [Re: mopar dave] #2561700
10/10/18 12:13 AM
10/10/18 12:13 AM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
That's the only one I've found that fills the bill. Pricy, though, at over $200/tire for 28"! Ouch!
Re: Taller front radial tire? [Re: GY3] #2561710
10/10/18 12:41 AM
10/10/18 12:41 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Not to mention ugly as heck, with that funky tread pattern. I’ve written M/T about this very subject in the recent past. With all the good radial rear rear tires these days, the market is void of drag-specific radial front runners. I’ve gotten no response from them which is disappointing. But I’ve got to believe they can see the hole in their lineup, and the market potential (??).
Re: Taller front radial tire? [Re: BradH] #2561770
10/10/18 03:19 AM
10/10/18 03:19 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Tex
What brand?
Tex
shoot , just realised I have Federal brand on front at the moment
its a pain with the reduction of tyre sizes available now
Tex
New best MPH 130.32
Re: Taller front radial tire? [Re: GY3] #2561784
10/10/18 07:22 AM
10/10/18 07:22 AM
Finland
LUMI Offline
LUMI  Offline
Finland
Dunlop makes nice oldtimer tire 185/80 R15 93W
not cheap
https://www.1001renkaat.com/renkaat-auto/dunlop/sport-classic/185-80-r15-93w-827990
Re: Taller front radial tire? [Re: GY3] #2561833
10/10/18 11:10 AM
10/10/18 11:10 AM
an8sec70cuda Offline
The M/T Sportsman SR fronts are the ONLY tall AND skinny radials out there. Everything else is either 26" or shorter. Most are 25", no matter what the online measurements tell you. Anything taller than 26" gets too wide to be considered a "skinny" to me, except for the M/Ts.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Taller front radial tire? [Re: an8sec70cuda] #2561967
10/10/18 03:30 PM
10/10/18 03:30 PM
Finland
LUMI Offline
LUMI  Offline
Finland
but only 1040 lbs max load spank
not enough for us heavy iron big blog B body guys runaway
Re: Taller front radial tire? [Re: GY3] #2561973
10/10/18 03:37 PM
10/10/18 03:37 PM
LUMI...You probably believe a 165R15 tire will blow out at speeds above 112 mph too.
CHIP
Re: Taller front radial tire? [Re: GY3] #2561975
10/10/18 03:39 PM
10/10/18 03:39 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I've looked over several cars, and have come to the conclusion an awful lot of race cars out there are running either radial slicks or drag radials in the back, along with bias ply front runners.
Nobody seems to want to talk about it, but I wonder if they have any issues. Probably no (?)
Re: Taller front radial tire? [Re: an8sec70cuda] #2561983
10/10/18 03:50 PM
10/10/18 03:50 PM
Finland
LUMI Offline
LUMI  Offline
Finland
yes i am a believer too eek
that dunlop is rated 270kmh = 167mph
