727 shield #2559387
10/05/18 01:29 PM
10/05/18 01:29 PM
Martinsville, IN
cdwmotorsports Offline OP
Martinsville, IN
Anyone have suggestions on what to get and what to stay away from?
eBay-cdwmotorsports
Re: 727 shield [Re: cdwmotorsports] #2559397
10/05/18 01:48 PM
10/05/18 01:48 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I have a CSR on a 727 in a A body. I have the stock floor, so I had to roll/beat the lip where the firewall seam meets the floor pan. Fits nicely once you get everything clearanced. I like it better than the trans blanket I had.
Re: 727 shield [Re: cdwmotorsports] #2559428
10/05/18 02:28 PM
10/05/18 02:28 PM
I like and used the blankets after fighting a CSI shield in a A body,1971 Duster, with the BB moved back one inch from stock on the trans crossmember shruggy work
Re: 727 shield [Re: cdwmotorsports] #2559530
10/05/18 05:06 PM
10/05/18 05:06 PM
Minn
SportF Offline
SportF  Offline
Minn
I like a blanket 'cause I personally saw a shield turn into a yellow ball of yarn that did NOTHING to prevent fragments from coming through the floor. Driver almost lost his foot.
Many of you heard me tell that above story before.
The drivers foot and toes basically turned black, and the doctor was prepping to remove a large part of it when he brushed across the toes. The patient groaned when that happened, and then the doctor did it again.
At this point the driver said why did you do that again? Doctors reply, you can feel that? Well, then, we need a different approach...…
Re: 727 shield [Re: SportF] #2559586
10/05/18 06:49 PM
10/05/18 06:49 PM
Martinsville, IN
Martinsville, IN
Do you have trans. temp issues with Blanket? I'm not opposed to a blanket aside from the temp issue
eBay-cdwmotorsports
Re: 727 shield [Re: cdwmotorsports] #2559631
10/05/18 08:40 PM
10/05/18 08:40 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
I run a blanket . Have not seen any temp issues , daily driven with a 5800 stall .
I do run a short blanket .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: 727 shield [Re: cdwmotorsports] #2559659
10/05/18 09:43 PM
10/05/18 09:43 PM
NO! grin
That's is not to say you won't have any heating issues though shruggy work My current bracket car with a glide that now stalls around 5600 RPM against the brake runs under 150 F all the time at the track, I have to warm the tranny up against the brake to get heat into the fluid shruggy
Re: 727 shield [Re: cdwmotorsports] #2559674
10/05/18 10:18 PM
10/05/18 10:18 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
CSR.... covers my “needs” for 9sec passes per the rules. Provides both trans and flex plate protection..... per the rules. Small block/727 combo I said f’it and cut the trans tunnel out. Even guys I talked to with 904 said it was TIGHT. I’m currently changing to 904 and have had a shield on order since July 2nd. Luckily I’ve had little ambition to get the car runnng, but f I did, I’d a thrown my old Lofgren blanket on it and called it good.
...my personal thought with a 727 is DONT GO to the track with a stock drum. I also feel a properly installed blanket is worlds above the CSR shield. It’s ability to absorb the shock/explosion makes much more sense.... hangup on the blanket is that I’d still need the required “flex plate/flywheel” sheild, so CSR it is.
Re: 727 shield [Re: cdwmotorsports] #2559814
10/06/18 11:53 AM
10/06/18 11:53 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
One advantage of the shield has is that it only needs to be recertified every five years, the blankets are every two years.
If you get a blanket Stroud Safety well recertify theirs, not everyone will.
Stroud will custom make them also. As alluded to above if you are in the nines you will need a SFI flexplate and flexplate shield.
Re: 727 shield [Re: cdwmotorsports] #2560749
10/08/18 10:43 AM
10/08/18 10:43 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
I run the CSR shield. I had one on my cuda's 727 when it exploded 10 years ago and it did it's job protecting me. No complaints here.
Basically your only options are the CSR shield or a blanket in a stock body car. I prefer the shield.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 727 shield [Re: cdwmotorsports] #2560822
10/08/18 12:35 PM
10/08/18 12:35 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
When building the car I opened up the tunnel. Worth the time and effort. Aluminum shield fits easily. Trans removal is also easy. No worries of whether the carbon shield will do the job.
Doug
Re: 727 shield [Re: dvw] #2561334
10/09/18 11:38 AM
10/09/18 11:38 AM
moparx Offline
moparx  Offline
doug, are you talking about the bolt together shield made of 1/4" aluminum plate ?
beer
Re: 727 shield [Re: moparx] #2561390
10/09/18 01:35 PM
10/09/18 01:35 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Yes
Re: 727 shield [Re: cdwmotorsports] #2561410
10/09/18 02:03 PM
10/09/18 02:03 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Let me throw a Q in here .. Why does an alum shield have to be recerted if it is not damaged ? uNless it is all about just THEM dipping into OUR WALLET again !!
Re: 727 shield [Re: cdwmotorsports] #2561445
10/09/18 03:08 PM
10/09/18 03:08 PM
NE Ohio
DoubleD Online content
DoubleD  Online Content
NE Ohio
the CSR shield solves both the transmission and Flywheel rule - actually has two SFI numbers on it - as with all safety products some minor adjustements needed - as in get the BFH out of the tool box!
Re: 727 shield [Re: dOrk !] #2561501
10/09/18 05:36 PM
10/09/18 05:36 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Nobody ever checks them.
Doug
Re: 727 shield [Re: cdwmotorsports] #2561506
10/09/18 05:44 PM
10/09/18 05:44 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
You mean no one at track tech eyeballs them closely OR when you send them in for RE cert they jsta rubber stamp them ?
Re: 727 shield [Re: cdwmotorsports] #2561535
10/09/18 06:42 PM
10/09/18 06:42 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Never seen a tech guy crawl under the car. Only to look for the driveshaft Loop.
Doug
Re: 727 shield [Re: cdwmotorsports] #2561543
10/09/18 06:58 PM
10/09/18 06:58 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
How about on a car that has a remove able tunnel ? Anyone ever build one out of 1/4" steel plate ?
Re: 727 shield [Re: cdwmotorsports] #2561751
10/10/18 02:08 AM
10/10/18 02:08 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I’ve only talked with folks that run divisional/national level that have been inspected closely. I passed on a used 904 CSR a couple months ago... wish I would have jumped on it.
