Turn signal switch #2561036
10/08/18 07:24 PM
10/08/18 07:24 PM
Washington
madscientist Offline OP
Washington
I have a 1989 Dodge 150 and it needs a turn signal switch. I have scoured the web and every switch I find says WITH tilt wheel only.
Is this correct or is it wrong? Not sure I've seen a Dodge truck of that era with a tilt wheel. I suspect it should say WITHOUT tilt wheel and it's a web misprint.
Any ideas????
Re: Turn signal switch [Re: madscientist] #2561045
10/08/18 07:49 PM
10/08/18 07:49 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
If you can find the part number, super huge help in searching.
So I guess stupid question; you're saying your truck does not have tilt.
Facts are stubborn things.
Re: Turn signal switch [Re: madscientist] #2561057
10/08/18 08:17 PM
10/08/18 08:17 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
The fancier le trucks usually had tilt, which is then a Delco type column, makes it different from straight non tilt mopar. There's gotta be somebody servicing either type, I would hope...
Re: Turn signal switch [Re: madscientist] #2561060
10/08/18 08:28 PM
10/08/18 08:28 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
You're right. I just looked all over and EVERYWHERE lists with tilt.
Do you think they use the same switch in this case? I know it's usually a different one, but I checked rockauto, and several other sources and they all list w/tilt.
Re: Turn signal switch [Re: madscientist] #2561088
10/08/18 09:38 PM
10/08/18 09:38 PM
Washington
Washington
IDK what to think. I can't imagine they made more trucks with tilt than trucks without.
Ive looked everywhere and all I can find is those that say tilt only.
I'm stumped.
Re: Turn signal switch [Re: buildanother] #2561089
10/08/18 09:40 PM
10/08/18 09:40 PM
Washington
Washington
I'll have to walk out and look but IIRC my truck is the LE model, although it's a 318 with a stick it has every other option...except tilt.
I may be screwed unless I can find a switch or someone knows someone who can repair the switch.
Re: Turn signal switch [Re: madscientist] #2561155
10/08/18 11:23 PM
10/08/18 11:23 PM
chicagoland,usa
chicagoland,usa
Thats why I said usually, because I believe some years with man trans could not be ordered with tilt. What's wrong with your switch anyway? I'm sure somebody could hook ya up with good used.
Re: Turn signal switch [Re: madscientist] #2561169
10/08/18 11:45 PM
10/08/18 11:45 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
i looked up a 1989 and 1986 d150 at rock auto, they both list an sm126 part number for tilt wheel.
but the 86 application also lists some switches for non tilt wheel so maybe try that application...
Re: Turn signal switch [Re: madscientist] #2561189
10/09/18 12:19 AM
10/09/18 12:19 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The 89 tilt is the same column above the tilt for nearly all Mopars 88 until the air bag started to come into play around 92/93.
I suspect you will find the non-tilt column takes the same switch from around 80 or 81 up the the air bag era.
The mid-late 70s columns (both tilt and non-tilt) were different then the 81/82 - early 90s, and the year to two before the air bags are different again.
Re: Turn signal switch [Re: buildanother] #2561330
10/09/18 11:30 AM
10/09/18 11:30 AM
Washington
Washington
I'm not exactly sure what's wrong with the switch except the TS almost never blink on the dash, but the hazards always do.
I can hear the flasher going off, but nothing blinks. Then, once in a while, the turn signals will blink at the bulbs, but the dash indicators don't blink. And then, if I forget and keep using the switch, the right side dash light and bulbs will flash maybe half a dozen times and then they quit.
I'm a bit nervous about buying used electrical stuff. I've never been successful with used electrical parts.
I'm not sure how common this is. It's a pain in the ass for sure, because you never know if the blinkers are working or not.
Re: Turn signal switch [Re: madscientist] #2561335
10/09/18 11:39 AM
10/09/18 11:39 AM
P
Porter67 Offline
Porter67  Offline
P
Ha Ha Ha....
To quote you on the oil slinger issue....
"No wonder this sport is dying. It should die for all the stupid that goes on."
AND now the super genius of the mopar world says "I have a 1989 Dodge 150 and it needs a turn signal switch" and cant source one....
PRICELESS!
Re: Turn signal switch [Re: Porter67] #2561336
10/09/18 11:42 AM
10/09/18 11:42 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Originally Posted By EV2Bird
Ha Ha Ha....
PRICELESS!
Badscientist strikes again.
Based on the symptoms, I'd just fix the one I had.
Don't be the exception.
Re: Turn signal switch [Re: Supercuda] #2561370
10/09/18 12:58 PM
10/09/18 12:58 PM
NY
twodoorpost Offline
twodoorpost  Offline
NY
Here's the page from the 1988-1989 factory parts book.
Re: Turn signal switch [Re: madscientist] #2561433
10/09/18 02:51 PM
10/09/18 02:51 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Re: Turn signal switch [Re: Porter67] #2561434
10/09/18 02:51 PM
10/09/18 02:51 PM
Washington
Washington
Ha Ha Ha....
PRICELESS!
Well then find one for me and be my hero.
Jackoff
Re: Turn signal switch [Re: Supercuda] #2561436
10/09/18 02:53 PM
10/09/18 02:53 PM
Washington
Washington
Ha Ha Ha....
PRICELESS!
Well how about I send you this one and YOU fix it. Wait, you can't degree a cam, and your buddy above thinks an oil slinger is an important piece in a race engine.
You two dildos have nothing to offer, as is usual.
Re: Turn signal switch [Re: Supercuda] #2561439
10/09/18 02:57 PM
10/09/18 02:57 PM
Washington
Washington
Well [censored], that's the first one for the non tilt wheel. Evidently SMP is the only one making it. The price is outrageous.
Re: Turn signal switch [Re: madscientist] #2561444
10/09/18 03:05 PM
10/09/18 03:05 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
If you want I have a 10lb sledge that you can borrow and use it to hammer it where the sun don't shine. BTW genius, I know how to degree a cam, I know several way to do that as well. I also know [ Moparts Family Site - Keep it Friendly ] multi-viscosity oil is, which you don't and you apparently conflated me with someone else in the process.
So clown, I suggest you think before you post because you are a super genius on the Wile E. Coyote level.
Re: Turn signal switch [Re: Supercuda] #2561498
10/09/18 05:27 PM
10/09/18 05:27 PM
Washington
Washington
Thanks for the tip. You evidently just come here to bust my balls but since you are an insignificant speck on a gnats ass I don't care.
Don't post in my threads if you don't like what I say. You've never proven me wrong, you just another keyboard sissy.
Later dude.
Re: Turn signal switch [Re: madscientist] #2572265
10/31/18 05:25 PM
10/31/18 05:25 PM
Conroe , Texas
I
iapco103 Offline
iapco103  Offline
I
Conroe , Texas
I realize I am late to the party , but what you probably need is the turn signal cam ( it breaks at the pivot point )
search for SHEE-MAR SM-20 on ebay ( about $10-$12 )
this may solve the problem
Paul
