I have a 1989 Dodge 150 and it needs a turn signal switch. I have scoured the web and every switch I find says WITH tilt wheel only.
Is this correct or is it wrong? Not sure I've seen a Dodge truck of that era with a tilt wheel. I suspect it should say WITHOUT tilt wheel and it's a web misprint.
Any ideas????
Just because you think it won't make it true. Horsepower is KING. To dispute this is stupid. C. Alston
