FiTech FCC Acting up - Looking for 1974 Satellite in tank FP
#2559290
10/05/18 09:58 AM
10/05/18 09:58 AM
Posts: 8,430 St Charles MO
70Coronet500Vert
St Charles MO
Title says it all. Does anyone know of a sumped tank for a 1974 Satellite? Damn car has everything weird on it.
I am going to search for others setups for electric fuel pumps to the EFI unit. Just started acting up.
I guess at idle it is boiling fuel. We sit and watch the pressure gauge go from 43 lbs down into the 30s and the car dies. Need to change it out.
No matter how responsible he may seem, never give your gun to a monkey! 1970 Coronet Vert 1972 Charger 1974 Satellite Sebring Plus Sundance 2001 Ram 4x4 2002 Intrepid 2006 300C
Re: FiTech FCC Acting up - Looking for 1974 Satellite in tank FP
[Re: 70Coronet500Vert]
#2559471
10/05/18 03:32 PM
10/05/18 03:32 PM
Posts: 528 SW CO
HemiSportFury
SW CO
Since you have already invested in the FCC, what do you have for a return line from the FCC to the tank? I know they call it a vent line, but if you read all the instructions and user comments it's clear it's a return line and not just a vent. With a good unrestricted return others have gotten the FCC to work. You will need a return if you go in-tank anyway, so why not try it first?
I went with the in-tank setup for my 64 after reading the comments on the FCC. Had to modify my existing tank to put the Aeromotive Phantom 340 in it.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60 '57 Belvedere 2dr sedan, current project in process '19 Cherokee Trail Hawk Elite '03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
#2559607
10/05/18 07:52 PM
10/05/18 07:52 PM
70Coronet500Vert
St Charles MO
Well as I described, the fuel pressure just slowly fades away as the car is being driven or sits and idles. Either the mechanical fuel pump is bad of the fuel pump in the sump is getting hot. I think.
We are looking at running a full return line this weekend and then removing the float and brass filter from the command center as others have done and see if this keeps the pump cool. The command center has been on the car over a year and the car recently starting having problems staying running. Def fuel related.
#2559648
10/05/18 09:24 PM
10/05/18 09:24 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Maybe there is a vacuum being created
[Re: Supercuda]
#2559740
10/06/18 02:11 AM
10/06/18 02:11 AM
Posts: 16,146 Mesa, Arizona
dart4forte
Mesa, Arizona
Give AndyF a jingle. He may have a solution to your issue.
Abe Lincoln
[Re: HemiSportFury]
#2559908
10/06/18 03:07 PM
10/06/18 03:07 PM
Posts: 15,864 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I went with the in-tank setup for my 64 after reading the comments on the FCC. Had to modify my existing tank to put the Aeromotive Phantom 340 in it. He's right, not just a vent, it's DEFINITELY a return line. I learned this from experience, so if you haven't done this yet, try it first.
Facts are stubborn things.
#2559997
10/06/18 06:26 PM
10/06/18 06:26 PM
Posts: 25,791 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Well as I described, the fuel pressure just slowly fades away as the car is being driven or sits and idles. Either the mechanical fuel pump is bad of the fuel pump in the sump is getting hot. I think. If not already done, the pump can be slowed down at idle and low speeds to prevent overheating; read the part about PWM in the link below. https://fitechefi.com/faq/fuel-pump-control/I do not believe the vent on the FCC is intended to be a return line under normal conditions, it vents vapors and act as a relief if the internal float fails to shut off fuel flow. I've never seen fuel flow from my vent.
#2561047
10/08/18 08:01 PM
10/08/18 08:01 PM
70Coronet500Vert
St Charles MO
I am going to do the FCC modification and run a full 3/8s return line.
I will remove float and bronze filter and just let the fuel circulate. I let this car idle for 30 mins trying to bring it up to temperature and the sump was too hot to touch. That cant be good for th efuel.
