Page 2 of 3 1 2 3
Re: 727 park grind [Re: John_Kunkel] #2556107
09/28/18 09:48 PM
09/28/18 09:48 PM
las vegas,nv
mopar muscle7271 Offline OP
las vegas,nv
Your right it isnt fully engaging in park,i disconnected the linkage the lever on transmission wasnt in park.push the lever on transmission all the with up with my hand to put in park.
Re: 727 park grind [Re: mopar muscle7271] #2558029
10/02/18 11:41 PM
10/02/18 11:41 PM
las vegas,nv
las vegas,nv
Is this a console floor shift lower rod? the seller isn't sure
Re: 727 park grind [Re: mopar muscle7271] #2558468
10/03/18 05:49 PM
10/03/18 05:49 PM
las vegas,nv
las vegas,nv
All you mopar people on here dont know if it is the right lower rod for a floor shift?
Re: 727 park grind [Re: mopar muscle7271] #2558549
10/03/18 08:08 PM
10/03/18 08:08 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Maybe if you'd post a pic that can actually be seen..........
Re: 727 park grind [Re: mopar muscle7271] #2558645
10/03/18 10:56 PM
10/03/18 10:56 PM
las vegas,nv
las vegas,nv
Pic of rod
Re: 727 park grind [Re: John_Kunkel] #2558648
10/03/18 11:01 PM
10/03/18 11:01 PM
las vegas,nv
las vegas,nv
New pic is up
Re: 727 park grind [Re: mopar muscle7271] #2558960
10/04/18 04:23 PM
10/04/18 04:23 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Looks like a console rod to me, but did you check for missing/worn plastic bushings as suggested earlier?
Re: 727 park grind [Re: mopar muscle7271] #2559012
10/04/18 07:01 PM
10/04/18 07:01 PM
Guitar Jones Offline
Did you try adjusting it first? Shifter in park, loosen the 1/2 " head bolt so it will slide on the rod, push the Trans lever fully rearward then tighten the bolt.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 727 park grind [Re: John_Kunkel] #2559112
10/04/18 10:31 PM
10/04/18 10:31 PM
las vegas,nv
las vegas,nv
Ok cool,yah they do need to be replaced.where u find the right ones at?
Re: 727 park grind [Re: Guitar Jones] #2559251
10/05/18 03:58 AM
10/05/18 03:58 AM
las vegas,nv
las vegas,nv
soon as i get that other rod above and bushings i will do that.
Re: 727 park grind [Re: mopar muscle7271] #2559934
10/06/18 04:44 PM
10/06/18 04:44 PM
las vegas,nv
las vegas,nv
No one knows where to find throttle rod bushings at?
Re: 727 park grind [Re: mopar muscle7271] #2559944
10/06/18 05:00 PM
10/06/18 05:00 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you tried searching online?
Re: 727 park grind [Re: stumpy] #2559977
10/06/18 05:27 PM
10/06/18 05:27 PM
las vegas,nv
las vegas,nv
Yah not much luck
Re: 727 park grind [Re: mopar muscle7271] #2559988
10/06/18 06:16 PM
10/06/18 06:16 PM
Have you tried a dealer?
Re: 727 park grind [Re: mopar muscle7271] #2560007
10/06/18 06:46 PM
10/06/18 06:46 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Throttle rod bushings for the shift linkage? Try looking for shift linkage bushings part # 3575434.
Re: 727 park grind [Re: Guitar Jones] #2560286
10/07/18 11:48 AM
10/07/18 11:48 AM
las vegas,nv
las vegas,nv
I haven't yet,they still carry them?
Re: 727 park grind [Re: John_Kunkel] #2560287
10/07/18 11:50 AM
10/07/18 11:50 AM
las vegas,nv
las vegas,nv
I need the two bushing that go at end of the lower rod.
Re: 727 park grind [Re: mopar muscle7271] #2560331
10/07/18 12:55 PM
10/07/18 12:55 PM
Hopefully Ma still carrys em so you dont have to go to a yard for something that small.
Re: 727 park grind [Re: mopar muscle7271] #2560400
10/07/18 04:22 PM
10/07/18 04:22 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If you're talking about the lower rod mentioned earlier, there are no bushings at the rod ends. The plastic bushings shown above are used in the vertical linkage rod.
Re: 727 park grind [Re: John_Kunkel] #2560574
10/07/18 11:13 PM
10/07/18 11:13 PM
las vegas,nv
las vegas,nv
Ok,though there was black bushings one that goes into transmission control lever lever that the rod goes into and the other at the end of torque shaft that the rod goes into?
Page 2 of 3 1 2 3
