Re: 727 park grind
[Re: mopar muscle7271]
#2558549
10/03/18 08:08 PM
10/03/18 08:08 PM
Posts: 25,785 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Maybe if you'd post a pic that can actually be seen..........
Re: 727 park grind
#2558960
10/04/18 04:23 PM
10/04/18 04:23 PM
John_Kunkel
Rio Linda, CA
Looks like a console rod to me, but did you check for missing/worn plastic bushings as suggested earlier?
Re: 727 park grind
#2559012
10/04/18 07:01 PM
10/04/18 07:01 PM
Guitar Jones
Did you try adjusting it first? Shifter in park, loosen the 1/2 " head bolt so it will slide on the rod, push the Trans lever fully rearward then tighten the bolt.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
Re: 727 park grind
[Re: John_Kunkel]
#2559112
10/04/18 10:31 PM
10/04/18 10:31 PM
Posts: 459 las vegas,nv
mopar muscle7271
las vegas,nv
Ok cool,yah they do need to be replaced.where u find the right ones at?
Re: 727 park grind
[Re: Guitar Jones]
#2559251
10/05/18 03:58 AM
10/05/18 03:58 AM
mopar muscle7271
las vegas,nv
Did you try adjusting it first? Shifter in park, loosen the 1/2 " head bolt so it will slide on the rod, push the Trans lever fully rearward then tighten the bolt. soon as i get that other rod above and bushings i will do that.
Re: 727 park grind
#2559988
10/06/18 06:16 PM
10/06/18 06:16 PM
Guitar Jones
Re: 727 park grind
#2560007
10/06/18 06:46 PM
10/06/18 06:46 PM
John_Kunkel
Rio Linda, CA
No one knows where to find throttle rod bushings at? Throttle rod bushings for the shift linkage? Try looking for shift linkage bushings part # 3575434.
Re: 727 park grind
#2560331
10/07/18 12:55 PM
10/07/18 12:55 PM
RapidRobert
Hopefully Ma still carrys em so you dont have to go to a yard for something that small.
Re: 727 park grind
#2560400
10/07/18 04:22 PM
10/07/18 04:22 PM
John_Kunkel
Rio Linda, CA
I need the two bushing that go at end of the lower rod. If you're talking about the lower rod mentioned earlier, there are no bushings at the rod ends. The plastic bushings shown above are used in the vertical linkage rod.
Re: 727 park grind
[Re: John_Kunkel]
#2560574
10/07/18 11:13 PM
10/07/18 11:13 PM
mopar muscle7271
las vegas,nv
Ok,though there was black bushings one that goes into transmission control lever lever that the rod goes into and the other at the end of torque shaft that the rod goes into?
