Re: Big block re-pop 6 quart oil pan total capacity w/filter?
[Re: KillerBee]
#2559044
10/04/18 08:24 PM
10/04/18 08:24 PM
Posts: 43,215 Bend,OR USA
Cab_Burge
Which brand, part number and what motor and body style pan are you asking about?
[Re: KillerBee]
#2559059
10/04/18 08:52 PM
10/04/18 08:52 PM
Posts: 619 nj
JAMESDART
nj
[Re: KillerBee]
#2559157
10/05/18 12:16 AM
10/05/18 12:16 AM
Cab_Burge
That is a copy of the original Mopar 1970/71 hemi and 440 6 pack 6 quart oil pan, I use them all the time It holds six quarts in the pan and you need to add one quart for the stock type oil filter Do NOT use the Summit oil pick up in that pan It ends up about two to two and half inches above the bottom of that pan I bought one of Pioneers stock OEM replacement 3/8 pick up for that pan that works excellent I made a post about the pick up on here earlier this year with the part # Sorry I don't have a link to it for you
[Re: KillerBee]
#2559396
10/05/18 01:46 PM
10/05/18 01:46 PM
Posts: 6,497 N.E. Ohio
KillerBee
N.E. Ohio
Thanks for the replies.
The oil pan is on a freshly rebuilt 1968 440 engine with Six Pack that's in my wife's 71 R/T Challenger.
The engine is running great and I'm getting ready to change out the break in oil.
I did use Summit's recommended oil pickup with their pan but everything was checked by my engine builder and the engine will not be driven hard so hopefully there will be no issues.
[Re: KillerBee]
#2559423
10/05/18 02:18 PM
10/05/18 02:18 PM
Cab_Burge
Are you going to change the oil yourself or have it done? If you do it take the oil dipstick out before draining the oil and after most or all of the oil has drain out take the dipstick out and use it to see how close the oil pickup is to the bottom of the oil pan through the oil drain plug hole I shoot for contact at the front of the pickup to no more than the width of the dipstick sideways between the lowest part of the pick up to the pan bottom If it is higher than that I remove the pan on the engine stand and do what is needed to get it to fit the way the factory service manuals recommends
[Re: NANKET]
#2559525
10/05/18 04:57 PM
10/05/18 04:57 PM
KillerBee
N.E. Ohio
Thanks guys.
I already did the oil/filter change myself.
I'm using a chrome aftermarket dipstick/tube and the oil level after 7 quarts was high on the dipstick. I wanted to make sure I didn't have too much oil in it at 7 quarts and needed to remove a quart. I ran the engine, let it site overnight then made a mark on the dipstick where the oil level was.
I discussed the oil pickup depth and windage tray clearance along with a bunch of other questions with the engine builder back when I dropped off the engine and all the parts. He told me he always mocks up the pan and checks the oil pickup depth and location on his builds.
He is a reputable Mopar engine builder who has built some very fast Mopar big blocks, some for members here at Moparts which is where I got his reference from.
I'm sure if the pickup wasn't in the right spot he would have modified or replaced the pickup I gave him.
