Best tires? #2558131
10/03/18 10:18 AM
10/03/18 10:18 AM
gregsdart Online content OP
gregsdart  Online Content OP
Currently run Goodyear 15x33x15 2078 slicks, trap 7400. 14 inch rims, Torqueflite, 4.56 gears,3065 lbs. 1.25 to 1.27 60 ft, 8.90 et.
I only have room for 17.8 section width.
I am considering Hoosier 32 x13.5w #18245
,but am concerned about trap rpm going much above 7500. Opionions on the Hoosiers vs Goodyears? Other options?
Re: Best tires? [Re: gregsdart] #2558274
10/03/18 02:44 PM
10/03/18 02:44 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I am a huge M/T fan myself. I have run all three and for my the best results have been with M/T's over time. Goodyears work well until they don't and it seems to be like flipping a switch. Hoosiers worked fine as well and held air better than M/T's for sure. But my best results have always been M/T's, best 60's, best ET's.
Re: Best tires? [Re: gregsdart] #2558302
10/03/18 03:22 PM
10/03/18 03:22 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
10.5wx33 M/T. More than enough tire.
Doug
Re: Best tires? [Re: gregsdart] #2558318
10/03/18 03:42 PM
10/03/18 03:42 PM
M/T doesn't have a size in stiff sidewall for my rims or section width, from what i see. So it looks like the Hoosiers are about my only option, unless i try a 12 inch rim and try the 10.5x33 mt.
DVW, do you run tubes?
Re: Best tires? [Re: gregsdart] #2558362
10/03/18 04:12 PM
10/03/18 04:12 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I have always run Hoosiers. Love them.
Always ran tubes in bias ply tires, dont in my current radials
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Best tires? [Re: gregsdart] #2558701
10/04/18 12:51 AM
10/04/18 12:51 AM
ky
68roadrunner Offline
ky
that hoosier is the one i run on the roadrunner. its like 104 rollout, good stiff sidewall 3300lb ladder bar car. they stopped working at 180 passes, when the corded started showing lol
Re: Best tires? [Re: gregsdart] #2558708
10/04/18 01:07 AM
10/04/18 01:07 AM
baldwinsville new york
a493demon Offline
a493demon  Offline
Why couldn't you run the 33x10.5 on a 14 inch wheel ?
I run a 28x10.5 on a 12 inch wheel
Re: Best tires? [Re: gregsdart] #2558759
10/04/18 07:17 AM
10/04/18 07:17 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Yes I run tubes. Plenty of guys running 33" on 14" rim. Mine are 31". I'd like a 12" rim but only have 10". Still works pretty good, 1.25 60ft last weekend.
Doug
Re: Best tires? [Re: gregsdart] #2558899
10/04/18 02:15 PM
10/04/18 02:15 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
While it is LIKELY enough tire for your less than ideal suspension. the 10.5x33w on a 12" wheel should be similar diameter. 14" will shrink it, but again most I have seen use a 14" and currently the 'outlaw' guys are beadlocking a 16x16 10.5wx33x16...not that that remotely applies
Re: Best tires? [Re: HardcoreB] #2558904
10/04/18 02:23 PM
10/04/18 02:23 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Come to think of it, I have the 10.5wx33x15 on an odd 13" beadlock Weld wheel...I can measure it when I get home if you wish?
Re: Best tires? [Re: HardcoreB] #2558949
10/04/18 04:10 PM
10/04/18 04:10 PM
Great, Hardcore!
Re: Best tires? [Re: gregsdart] #2558953
10/04/18 04:19 PM
10/04/18 04:19 PM
If i were to try a 10.5w x 33 on a 14 inch rim, would it have less growth, due to the wide rim? Could i run it tubeless?
One other thing, on my 15.1 wide Goodyears on a 14 inch rim, the outside 2 inches on each tire look like they are not working as hard, maybe less heat during the burnout, or less contact due to distortion? My thinking is, if that is true, i am hauling extra wieght and slowing the car down as well. Opinions?
Re: Best tires? [Re: 68roadrunner] #2558964
10/04/18 04:43 PM
10/04/18 04:43 PM
What 60 ft times are you seeing with the Hoosiers? Do you run them tubeless? Also, you mention 104 inch rollout. Do they run larger than the advertised numbers?
Re: Best tires? [Re: gregsdart] #2559133
10/04/18 11:30 PM
10/04/18 11:30 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
I have always liked MT, the 33 10.5W in either 15 or 16 inch rim is an amazing tire for no more tread than they have. They do give up too quick for me as a bracket type tire. Meaning the sidewall goes away fast on a heavy car.
I have been becoming a hoosier fan more, and more. On one car there isn't much room for more than the MT 33 10.5 15W. Hoosier has a 33 13 15 that is a great working tire. I went from a best 60 on the smaller MT at 1.14 to a 1.09 with the hoosier, and I think it'll take a good bit more on the hit tuning the shock some. Also doesn't lose any air between rounds, and the mickey would lose air in the lanes.
On another car I ran the 33 10.5 16W with tubes and it too was great, but gave up on the sidewall too fast with a 3400 pound car. Have it on a hoosier now, but dealing with what feels like the edge of shake, and I'm out of shock to stop it. So I know it hooks harder, but I'll need shocks mods now to run it. Now i just drop the air pressure to take bite away, when I'd rather get after it.
Last car is on the goodyear PS slick 33.5 17 16. Great, hooks, holds air, sub 1 sec 60' but I know is only good for a max of 20 runs, before the sides are gone. The Hoosier will go 50 says WJ, and a couple other guys I know that beat on tires.
I guess the short of it is, I'd have to give a very slight edge to Hoosier at this point for myself. Mostly due to construction of the tire. MT, and goodyear are hand wound tires. Hoosier is totally automated, and more consistent tire to tire. That being said I think either tire is just as fast in the right hands.
Re: Best tires? [Re: gregsdart] #2561208
10/09/18 01:04 AM
10/09/18 01:04 AM
ky
ky
1.34 ish 60' 6.3x rt at 106mph, tubless and they will hold air for weeks.i will measure them this week
