Re: Hemi Shaft Rocker springs
[Re: Craig J]
#2557292
10/01/18 10:26 PM
10/01/18 10:26 PM
Posts: 43,247 Bend,OR USA
Cab_Burge
The pushrods won't allow that to happen The better you control the side movement of the rocker arms the more net lift the valves will see :up BTW, to get the best setup on each rocker arm location you may need to shim the other side of them also Another reason why I call them Hemiroid motors
[Re: Craig J]
#2557469
10/02/18 10:31 AM
10/02/18 10:31 AM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
FWIW...my 572 hemi has had the stock style spring setup on it since I built it in 2006. I will be changing to the clamps at the next freshen up b/c I'm curious if they'll help w/ valveguide wear.
You can see my setup here...my daughter was "helping".
[Re: Craig J]
#2557547
10/02/18 11:31 AM
10/02/18 11:31 AM
Posts: 2,666 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Looking at how light those springs are, I would think that my bad luck would cause the rocker to walk down the shaft and fall off the valve tip, resulting in an immediate and expensive failure. But I guess that really doesn't happen???
Everything's been fine for over 50 years. Your OCD is kicking in. Worry about something worth worrying about.
2011 Drag Pak Challenger
[Re: Craig J]
#2557552
10/02/18 11:34 AM
10/02/18 11:34 AM
Posts: 7,496 Minnesota
Hemi_Joel
Minnesota
Dick Landy claimed that the collars added horsepower by stabilizing the valve train. I don't remember how much.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#2557629
10/02/18 01:18 PM
10/02/18 01:18 PM
Posts: 314 Northeast Indiana
73DAD
Northeast Indiana
Dick Landy claimed that the collars added horsepower by stabilizing the valve train. I don't remember how much. Like I said earlier, I'd love to see a dyno test. Anecdotal evidence and opinions don't cut it these days, and that includes my own. We need an episode of Mythbusters featuring the 'ole 426!
[Re: 73DAD]
#2558149
10/03/18 10:55 AM
10/03/18 10:55 AM
Posts: 10 Beyond the Sun
SS_Dodge
Beyond the Sun
Look at the way the pushrods are angled. They side-load the rockers into the stands, not away. Spot on right there.
[Re: Craig J]
#2558155
10/03/18 11:09 AM
10/03/18 11:09 AM
Posts: 4,209 New York
polyspheric
New York
DL claimed that inventing products stabilized his bank balance.
Boffin Emeritus
