Hemi Shaft Rocker springs #2557264
10/01/18 09:47 PM
10/01/18 09:47 PM
West Palm Beach, Florida
Craig J Offline OP
Craig J  Offline OP
I apologize if this has been answered before, I searched and didn't find the answer.
Some stock(???) hemi rocker shafts use a light spring to push the rockers into position over the valve tip, others have a clamp to prevent the rocker from "walking" on the shaft.
Does either system have an advantage?
I am thinking about attempting a home built 572 and trying to sort out how to get a good rocker setup with stock valve covers. I was a chevy guy from 1986 - 2017 so I am trying to catch up a bit on mopar stuff.
Craig
Re: Hemi Shaft Rocker springs [Re: Craig J] #2557284
10/01/18 10:20 PM
10/01/18 10:20 PM
The clamps are a lot better way to set the rocker system up to avoid excessive side loading, to dang many angles on them 426 type Hemiroid motors whistling work
Re: Hemi Shaft Rocker springs [Re: Cab_Burge] #2557289
10/01/18 10:25 PM
10/01/18 10:25 PM
Craig J Offline OP
Craig J  Offline OP
Looking at how light those springs are, I would think that my bad luck would cause the rocker to walk down the shaft and fall off the valve tip, resulting in an immediate and expensive failure. But I guess that really doesn't happen???
Re: Hemi Shaft Rocker springs [Re: Craig J] #2557292
10/01/18 10:26 PM
10/01/18 10:26 PM
The pushrods won't allow that to happen shruggy
The better you control the side movement of the rocker arms the more net lift the valves will see :up
BTW, to get the best setup on each rocker arm location you may need to shim the other side of them also scope
Another reason why I call them Hemiroid motors shruggy
Re: Hemi Shaft Rocker springs [Re: Craig J] #2557469
10/02/18 10:31 AM
10/02/18 10:31 AM
an8sec70cuda Offline
FWIW...my 572 hemi has had the stock style spring setup on it since I built it in 2006. I will be changing to the clamps at the next freshen up b/c I'm curious if they'll help w/ valveguide wear.
You can see my setup here...my daughter was "helping".
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Hemi Shaft Rocker springs [Re: Craig J] #2557475
10/02/18 10:36 AM
10/02/18 10:36 AM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
I disagree Cab, I believe Landy first used those clamps along with his 'Landy tool' to swap out broken valvesprings in a hurry between rounds. Makes it easier to keep the rocker out of the way if you don't have to fight against a spring. Look at the way the pushrods are angled. They side-load the rockers into the stands, not away. The engineering department would have performed thousands of hours of valvetrain testing. If they had observed the Gen II needed sleeve spacers or clamps on that spring side, it would have been born with them.
A good test would be a back to back dyno pull with the clamps installed, and then with the clamps removed to see if there is a significant difference in power. Or if someone would run one with a camera and strobe installed in a junk valvecover.
Re: Hemi Shaft Rocker springs [Re: Craig J] #2557531
10/02/18 11:23 AM
10/02/18 11:23 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
Just a FYI: It is a simple shaft collar that can be purchased Mcmaster carr.
https://www.mcmaster.com/shaft-collars.
Re: Hemi Shaft Rocker springs [Re: Craig J] #2557547
10/02/18 11:31 AM
10/02/18 11:31 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Everything's been fine for over 50 years. Your OCD is kicking in. Worry about something worth worrying about.
2011 Drag Pak Challenger
Re: Hemi Shaft Rocker springs [Re: Craig J] #2557552
10/02/18 11:34 AM
10/02/18 11:34 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Dick Landy claimed that the collars added horsepower by stabilizing the valve train. I don't remember how much.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Hemi Shaft Rocker springs [Re: Hemi_Joel] #2557629
10/02/18 01:18 PM
10/02/18 01:18 PM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
Like I said earlier, I'd love to see a dyno test. Anecdotal evidence and opinions don't cut it these days, and that includes my own.
We need an episode of Mythbusters featuring the 'ole 426!
Re: Hemi Shaft Rocker springs [Re: Craig J] #2557877
10/02/18 07:20 PM
10/02/18 07:20 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
The pushrod angle jams the rocker into the stand. The spring just kept it to that side. Lash won't allow it to move too far the other way. As long as we're solving the issue, lets run torrington bearings on either side with a collar.
Re: Hemi Shaft Rocker springs [Re: dthemi] #2558046
10/03/18 12:09 AM
10/03/18 12:09 AM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
I agree with Rick. There's a touch of OCD floating around. My motor is 11yrs old with hundreds of 8 sec. passes on it. It has the Stage V rockers with the spring setup. Never had a problem.
Re: Hemi Shaft Rocker springs [Re: 73DAD] #2558149
10/03/18 10:55 AM
10/03/18 10:55 AM
Beyond the Sun
SS_Dodge Offline
SS_Dodge  Offline
Beyond the Sun
Spot on right there.
Re: Hemi Shaft Rocker springs [Re: Craig J] #2558155
10/03/18 11:09 AM
10/03/18 11:09 AM
New York
polyspheric Offline
polyspheric  Offline
New York
DL claimed that inventing products stabilized his bank balance.
Boffin Emeritus
Re: Hemi Shaft Rocker springs [Re: polyspheric] #2558367
10/03/18 04:14 PM
10/03/18 04:14 PM
Stage V sells a kit with the collars and a set of wave springs to help the rocker rotate with less friction, that set up is the cats meow up
