How often do you replace your shifter cable? #2557003
10/01/18 01:27 PM
10/01/18 01:27 PM
Newark, OH
Hunted Duck Offline OP
Newark, OH
I have the b&m rachet shifter with shiftnoid air. Been having problems this season and have changed rpm switch and other things well it bit me again this weekend. Worked great first 6 passes. So I'm down to changing the cable. Been in car for 8-10 years.
Re: How often do you replace your shifter cable? [Re: Hunted Duck] #2558084
10/03/18 02:46 AM
10/03/18 02:46 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
What problem? I never even think about it.
Re: How often do you replace your shifter cable? [Re: Hunted Duck] #2558090
10/03/18 03:08 AM
10/03/18 03:08 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I went through a couple early on with my car. Then I put a heat resistant sheath on it.... been a number of years now with no issues. It’s heat that kills ‘em.
If you got 8-10 years, however; I wouldn’t call that a problem, I’d call that maintenance.
Re: How often do you replace your shifter cable? [Re: StealthWedge67] #2558611
10/03/18 10:21 PM
10/03/18 10:21 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I have only replaced mine once in all the years I have had the car and only because it got too close to the header tube.
Re: How often do you replace your shifter cable? [Re: Hunted Duck] #2558688
10/04/18 12:26 AM
10/04/18 12:26 AM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Mines 30 yrs old. Still wks perfectly.
Ok
Re: How often do you replace your shifter cable? [Re: Hunted Duck] #2558740
10/04/18 03:11 AM
10/04/18 03:11 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Mine has been in my car since 2006 and still working good. Ron
Re: How often do you replace your shifter cable? [Re: 383man] #2558776
10/04/18 09:12 AM
10/04/18 09:12 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i replace mine every 100 years unless it gets burnt by the header.
Re: How often do you replace your shifter cable? [Re: bonefish] #2559261
10/05/18 05:36 AM
10/05/18 05:36 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
That hit the nail on the head. That's about the only reason most shifter cables go bad......to close or touching a header tube. Ron
